HIFIBERRY AMP4 Class D Amplifier Module TAS5756M for Raspberry Pi 2x30W
Amplifier and Headphone Amplifier Modules
Reference 19117
Bon à savoir
The HiFiBerry AMP4 is a DAC/amplifier designed to work with the RaspBerry Pi. It features a TI TAS5756M chip. This chip is a stereo amplifier integrating a Burr-Brown DAC. It delivers up to 2x 30W of power and supports 44.1-192kHz (16-32bit) streams. This amplifier module works equally well with 4 ohm or 8 ohm speakers.Last items in stock!
- Paiement sécurisé
Ce qu'il fait
The HiFiBerry AMP4 is a DAC / amplifier module designed to work with the RaspBerry Pi. It features a TI TAS5756M chip. This chip is a stereo amplifier integrating a Burr-Brown DAC. It delivers up to 2x 30W of power and supports 44.1-192kHz (16-32bit) streams. This amplifier module works equally well with 4 ohm or 8 ohm speakers.
We recommend powering this module with a voltage between 12V and 20V for use with a 4 ohm load, and 12V to 24V for an 8 ohm load. The HifiBerry AMP4 is capable of powering the Raspberry PI, so an additional 5V supply is not required. However, it is not designed to power USB peripherals or other hardware that would require too much power and risk making the system unstable.
Finally, if you wish, this module can be used with HifiBerry's ADD-ON BOARD DSP to enable advanced digital signal processing possibilities. You can also bridge the outputs of both AMP4 channels.
If the software you're using doesn't provide AMP4 as an output option, you'll need to use the HiFiBerry DAC+ driver.
RaspBerry Pi compatibility: A+ / B+ / 2B / 3B / 3A+ / 3B+ / 4B / 5 / Zero / Zero W / Zero WH / Zero 2 W / Zero 2 WH
A single power supply is sufficient to power both the Raspberry Pi and the AMP4, directly via the latter.
| Specifications | |
| Product type | DAC / amplifier module for Raspberry Pi |
| Amplifier/DAC chip | TAS5756M |
| Input | GPIO |
| Outputs | 1x Channel 1 on screw terminal 1x Channel 2 on screw terminal |
| Other connectors | 1x DC jack 5.5/2.1mm for power supply 1x Screw terminal block for power supply |
| Compatible speaker impedance | 4-8 ohm |
| Supported sample rates | 24-32bit 44.1-192kHz |
| Max. output power | 2x 30W |
| THD+N | < 0.02% (typical, output power 0.1-10W) |
| SNR | 104dB |
| Frequency response | 20Hz-20kHz (output filter characteristics according to specific speaker parameters) |
| Recommended operating voltage | 12-20V |
| Maximum operating voltage | 24V |
| Typical output power per channel | 14W (Vsupply=12V, Rspk = 4Ohm, THD+N <0.1%) 18W (Vsupply=18V, Rspk = 4Ohm, THD+N <0.1%) 20W (Vsupply=24V, Rspk = 4Ohm, THD+N <0.1%) 8W (Vsupply=12V, Rspk = 8Ohm, THD+N <0.1%) 17W (Vsupply=18V, Rspk = 8Ohm, THD+N <0.1%) 28W (Vsupply=24V, Rspk = 8Ohm, THD+N <0.1%) |
| Max. output power per channel | 15W (Vsupply=12V, Rspk = 4Ohm, THD+N <10%) 30W (Vsupply=18V, Rspk = 4Ohm, THD+N <10%) 44W (Vsupply=24V, Rspk = 4Ohm, THD+N <10%) 10W (Vsupply=12V, Rspk = 8Ohm, THD+N <10%) 20W (Vsupply=18V, Rspk = 8Ohm, THD+N <10%) 38W (Vsupply=24V, Rspk = 8Ohm, THD+N <10%) |
| Recommended voltage per impedance | 12V-20V / 4 ohm 12V-24V / 8 ohm |
| Configuration | dtoverlay=hifiberry-dacplus |
| General | |
| Power supply | 12-24V DC via jack DC 5.5/2.1mm |
| Package | 1x HiFiBerry AMP 4 amplifier module |
| Condition | New |
