Amplifier Module 4.0 Class AB TDA7850 4x50W 4 Ohm
Amplifier Boards
RCAScrew terminals4Class A / ABTDA785050.0
Reference 18605
Bon à savoir
The TDA7850 is a class A/B amplifier module with MOSFET technology, featuring 4 channels and capable of delivering 4x50W output power at 4 ohms. The TDA 7850 chip, mounted on a heatsink for efficient heat dissipation, is the reason for its high power and rich, detailed sound reproduction.
€19.90Tax incl.
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
Photo of TDA7850 4.0 Amplifier Module
This TDA7850 class A/B amplifier module with MOSFET technology features 4 channels and is capable of delivering 4x50W output power at 4 ohms. The TDA7850 chip, mounted on a heatsink for efficient heat dissipation, is the reason for its high power and rich, detailed sound reproduction. This module offers high output current thanks to its rail-to-rail output structure and low distortion. Input is via a double RCA socket, and output is via screw terminals. This amplifier module accepts a voltage range from 12V DC to 18V DC, also via screw terminals.
Overview of the TDA7850 4.0 amplifier module
Input/output diagram for the TDA7850 4.0 amplifier module
1 DC 12V-18V power supply input on screw terminal block
2 RCA stereo input 1
3 RCA stereo input 2
4 Output 1 on screw terminal block
5 Output 2 on screw terminal block
6 Output 3 on screw terminal block
7 Output 4 on screw terminal block
Product type 4.0 amplifier module
Amplification type Class A/B
Amplification chip TDA7850
Number of channels 4.0
Inputs 2x RCA stereo
Outputs 4x Screw terminal block
Ouputs power 4x 50W @ 4 ohm (18V)
Supply voltages 12V DC Nominal
14.4V DC for rated power (50W)
18V DC Max
Dimensions 70x 40 x 75mm
Mounting holes 30 x 62
Weight 94g
Package 1x Amplifier module 4.0 Class AB TDA7850
Condition New
Input RCA
Output Screw terminals
Channel 4
Class Class A / AB
Amplifier chip TDA7850
Power (W) 50.0
Avis
Comments (0)
No customer reviews for the moment.
€19.90Amplifier Module 4.0 Class AB...
