ICEPOWER 1200AS2 Stereo Class D Amplifier Module 2x1200W 4 Ohm
Amplifier Boards
Reference 19116
Bon à savoir
This IcePower 1200AS2 amplifier module is a stereo Class D amplifier module based on ICEedge technology capable of delivering 2x 1200W @ 4 ohm (THD+N ≤ 1%). The module incorporates its own switched-mode power supply stage (SMPS) including a PFC (Power Factor Correction) to guarantee clean power supply to the amplifier stage.Available now
- Paiement sécurisé
Ce qu'il fait
This IcePower 1200AS2 amplifier module is a stereo Class D amplifier module based on ICEedge technology capable of delivering 2x1200W under 4 ohm (THD+N ≤ 1%). The module incorporates its own switching-mode power supply stage (SMPS) including a PFC (Power Factor Correction) to guarantee clean power supply to the amplifier stage. The power supply complies with ErP and ENERGY STAR standards. It also offers comprehensive protection and monitoring functions via an easy-to-use control interface. In fact, dedicated control outputs for speaker connector output voltage and current enable real-time protection of your sound system.
In addition, the 1200AS2 module is optimized for excellent heat dissipation thanks to an underlying aluminum plate, which also facilitates module mounting for rapid integration. The module also features a power output for easy powering of an external module, as well as 2 control ports.
This module has been designed to deliver state-of-the-art audio performance and power. This module is perfect for professional subwoofers, 2-way and 3-way loudspeakers, line arrays, consumer active loudspeakers or high-end amplifiers.
Overview of the ICEPOWER 1200AS2 amplifier module (Stereo)
| P100 | JST AC Mains Connector |
| P101 | Basic Control Connector |
| P102 | Advanced Control Connector |
| P103 | Hanger Control Connector |
| P104 | : Hanger Rail Supply Connector |
| P105 | Audio Input Connector |
| P106 | Voltage and Current Monitor Output Connector |
| P107 | Audio output channel 1 balanced |
| P108 | Audio output channel 2 balanced |
| Specifications | |
| Product type | Amplifier module |
| Amplification type | Class D |
| Channels | 2 (Stereo) |
| Inputs | 1x JST AC main power connector 3pins 1x HP JST audio input connector 6pins |
| Outputs | 1x JST channel 1 output connector 4pins 1x JST channel 2 output connector 4pins 1x JST output connector for voltage and current control 8pins 1x JST hanger rail supply connector 3pins 1x JST hanger control connector 8pins |
| Control ports | 1x JST basic control connector 14pins 1x JST advanced control connector 22pins |
| Output power | 2x 1200W @ 4 ohm (≤ 1%, 1kHz) 2x 600W @ 8 ohm (≤ 1%, 1kHz) |
| THD+N | 0.003 % THD+N @ 1 kHz, 10 W / 4 Ohm |
| Bandwidth | 50kHz |
| Dynamic range | 129dB |
| Output noise | 30uV A-weighted |
| Minimum load impedance | 2.7 Ohm |
| Maximum output voltage / current | 100Vp / 38Ap |
| Auxiliary supply outputs | +5VDC et +/-15VDC |
| General | |
| Power supply | 100-240V AC 50/60Hz |
| Dimensions | 300 x 100 x 63mm |
| Package | 1x ICEPOWER 1200AS2 stereo amplifier module 1x Cable kit for 1200AS2 |
| Condition | New |
| Input | PCB Connector |
| Output | PCB Connector |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | N/A |
| Power (W) | 1200.0 |
