TINYSINE TSA8800B Class D 2.1 Amplifier Module TPA3221 DAC DSP ADAU1701 Bluetooth 5.1 aptX HD 2x90W + 200W 4 ohm
Amplifier Boards
Reference 19431
Bon à savoir
The TinySine TSA8800B amplifier module combines the functions of a 2.1-channel Class D amplifier, DAC / DSP and integrates an AudioB I2S Bluetooth receiver supporting the high-resolution aptX and aptX HD codecs. It can deliver up to 2x90W of power and features a 200W subwoofer output. To achieve this, it uses TPA3321 amplifier chips. DAC / DSP signal processing is performed by an ADAU1701 chip, enabling tone adjustment for each channel. In addition to Bluetooth reception, a stereo RCA input is also available. This module also supports TWS, enabling several modules to be connected together.
€69.90Tax incl.
Including €0.05 for ecotax
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
The ADAU1701 DSP chip features a preloaded program for adjusting gain, bass, midrange and treble in the Sigma Studio DSP program/interface. A debug port is available for Sigma Studio. To access advanced features, users can program the TSA8802D module via TinySine's USBi programmer. The advanced functions available include equalization, crossover, bass enhancement, multiband dynamic processing, delay compensation and more. The TSA8802D amplifier module is powered by 12V-30V DC and is capable of driving passive speakers with an impedance of 2Ω, 4Ω or 8Ω.
Overview of the TinySine TSA8800B amplifier module
TinySine TSA8800B : Description diagram
1 External LED port
2 12-30V DC power supply input
3 RCA input
4 2x100W speaker output
5 200W subwoofer output
6 DSP in / out
7 External buttons port
8 Potentiometers port
9 Mute port
10 DSP progrmmation port
11 Audio output port
Port descriptions
DSP input/output port
Three input/output pins are available for the ADAU1701 DSP chip: MP6, MP7, MP0. It is possible to develop a DSP program to meet different requirements. For the default firmware, if you connect these pins to GND, the TSA8800B will emit a 1kHz sine wave.
Port for external buttons
There are three buttons on the module which can control volume, play/pause, etc... External buttons can also be connected using the dedicated port.
Pinout:
  • P/P  play / pause button
  • VOL +: volume up and fast forward
  • VOL -: volume down and fast rewind
  • 3.3V
TinySine TSA8800B : Pinout du port pour boutons externes
Potentiometer port
External potentiometers (5K-20K) can be connected to the module to control master volume, treble, midrange and bass. It is necessary to update the DSP software beforehand. A specially adapted potentiometer kit is sold separately.
Pinout:
  1. ADC0: main volume
  2. ADC1 : bass volume
  3. ADC2 : mid volume
  4. ADC3 : treble volume
DSP programming port
The TSA8800B's DSP detects both Bluetooth and RCA signals, but the default program gives higher priority to Bluetooth. If the Bluetooth signal is detected, the TSA8800B will output a Bluetooth audio source, otherwise the RCA output will take over. It's also possible to develop a DSP program to suit different needs, then load the new DSP program using the USBi JTAG Sigma DSP programmer (sold separately).
Connection modes and buttons
TinySine TSA8800B: Classic connection diagram
TinySine TSA8800B: Diagram of a TWS connection between two modules
TinySine TSA8800B : Control buttons diagram
  • S1: press and hold for 3s to activate pairing mode. Long press for 6s to reset pairing information
  • S1 + S2: Long press for 1s to activate TWS slave mode
  • S1 + S3: long press for 1s to activate TWS master mode
  • S2 + S3: long press for 1s to deactivate TWS mode
Product type Amplifier module
Amplification type Class D
Channels 2.1
Output power (stereo output) 2x 112W @ 3Ω, 10% THD+N
2x 105W @ 4Ω, 10% THD+N
2x 100W @ 3Ω, 1% THD+N
2x 88W @ 4Ω, 1% THD+N
Output power (subwoofer output) 208W @ 2Ω, 10% THD+N
Inputs Bluetooth 5.1
1x Stereo RCA
Outputs Speaker outputs on screw terminals
Subwoofer output on screw terminal
Bluetooth version 5.1
Supported Bluetooth codecs SBC, AAC, aptX, aptX HD
TWS support Yes
I2S Sampling rates 48kHz
Amplification chips TPA3221
DSP chip ADAU1701
THD+N 0.02% @ 1W
SNR 108dB @ A-wt, gain=18dB
Dynamic range 109dB @ A-wt, gain=18dB
Minimum load impedance 3-4Ω
Gain Min : 18dB
Typ : 24dB
Max : 34dB
Efficiency 90% @ 100W, 4Ω
Input impedance 48kΩ @ 18dB
24kΩ @ 24dB
12kΩ @ 30dB
7.7kΩ @ 34dB
Protections Over voltage
Under voltage
Over current
Over heat
Supply voltage 10-30V DC (power supply sold separately)
Dimensions 145 x 100 x 34mm
Package 1x TinySine TSA8800B module
1x Bluetooth antenna
Condition New
Avis
Comments (0)
No customer reviews for the moment.
€69.90TINYSINE TSA8800B Class D 2.1...
