TINYSINE TSA8802D Amplifier Module TPA3221 DAC / DSP ADAU1701 24bit 192kHz 2x100W 4 ohm
Amplifier Boards
Reference 19120
Bon à savoir
The TinySine TSA8802D amplifier module combines Class D stereo amplifier and DAC/DSP functions. It can deliver power up to 2x 100W, thanks to a TPA3321 amplifier chip. DAC/DSP signal processing is carried out by an ADAU1701 chip, enabling it to support streams up to 24bit 96kHz via its Toslink optical input (TOSLINKBee receiver).Including €0.05 for ecotax
Last items in stock!
- Paiement sécurisé
Ce qu'il fait
The TinySine TSA8802D amplifier module combines Class D stereo amplifier and DAC/DSP functions. It can deliver power up to 2x 100W, thanks to a TPA3321 amplifier chip. DAC/DSP signal processing is carried out by an ADAU1701 chip, enabling it to support streams up to 24bit 96kHz via its Toslink optical input (TOSLINKBee receiver). The TOSLINKBee receiver module converts the optical signal into an I2S signal, which is then processed by the ADAU1701 DAC/DSP chip before amplification. A stereo RCA input is also available on the module.
The ADAU1701 DSP chip features a preloaded program for adjusting gain, bass, midrange and treble in the Sigma Studio DSP program/interface. A debug port is available for Sigma Studio. To access advanced features, users can program the TSA8802D module via TinySine's USBi programmer. Advanced functions available include equalization, crossover, bass enhancement, multiband dynamic processing, delay compensation and more.
The TSA8802D amplifier module is powered by 12V-30V DC and can drive passive loudspeakers with 2 ohm, 4 ohm or 8 ohm impedance.
TINYSINE TSA8802D amplifier module overview
| 1 | DC connector power supply port (12V-30V DC) |
| 2 | Screw terminal block for power supply (12V-30V DC) |
| 3 | Fan power connector |
| 4 | Stereo RCA input |
| 5 | Toslink input via TOSLINKBee module |
| 6 | Gain DIP switch |
| 7 | DAC/DSP chip ADAU1701 |
| 8 | Control buttons on PCB: Vol-/previous - Vol+/next - Play/pause |
| 9 | DSP I/O control port |
| 10 | Port for external buttons (not available) |
| 11 | Port for external potentiometers |
| 12 | Mute port |
| 13 | Pre-out output |
| 14 | USBi DSP update port |
Please note that the external button port is not supported on the TSA8802D module.
TINYSINE TSA8802D: Ext POT port
The TinySine TSA8802D module features a dedicated port for connecting external potentiometers (5K - 20K) and controlling volume, bass, mid and treble. If you wish to use external potentiometers, TinySine offers a potentiometer KIT for this purpose, to be purchased separately.
- ADC0 - Main volume
- ADC1- Bass adjustment
- ADC2 - Middle adjustment
- ADC3 - Treble adjustment
Please note: to use external potentiometers, the module's DSP program must be updated to the version for external potentiometers, which can be found via our download tab.
TINYSINE TSA8802D: how do I load a new DSP program?
To load a new DSP program, you need a USBi JTAG DSP Sigma programmer. The default DSP program loaded on the module can automatically select either RCA line input or Toslink optical input, with priority given to the optical signal.
TINYSINE TSA8802D: gain adjustment via DIP switch
The TinySine amplifier module also features gain adjustment via DIP switch. The following settings are available:
- 18dB : OFF / OFF / OFF / ON
- 24dB : OFF / OFF / ON / OFF
- 30dB : OFF / ON / OFF / OFF
- 34dB : ON / OFF / OFF / OFF
| Specifications | |
| Product type | Amplifier module with DSP |
| Amplification chip | TPA3221 |
| DAC/DSP chip | ADAU1701 |
| Inputs | 1x RCA stereo 1x Optical Toslink (TOSLINK Bee receiver module) |
| Outputs | Stereo output on screw terminal 1x Pre-out output on PCB connector |
| Other connectors | 1x USBI DSP programmer port 1x Port for DSP control I/O 1x Port for external potentiometer |
| Buttons on PCB | Vol-/previous Vol+/next Play/Pause |
| Supported sample rates | SPDIF : 16bit/24bit 48KHz, 88.2KHz, 96KHz I2S : 16bit 48KHz |
| Output power | 112W (RL= 3Ω, 10% THD+N, 24V DC) 105W (RL= 4Ω, 10% THD+N, 24V DC) 100W (RL= 3Ω, 1% THD+N, 24V DC) 88W (RL= 4Ω, 10% THD+N, 24V DC) |
| THD+N | 0.02% (1W) |
| SNR | 108dB (A-weighted, Gain = 18dB) |
| DNR | 109dB (A-weighted, Gain = 18dB) |
| Minimum load impedance | 3Ω(Min.) 4Ω(Typical) |
| Gain | 18dB 24dB 34dB |
| Efficiency | 90% (100W @ 4Ohm) |
| Input impedance | 48KΩ (gain 18dB) 24KΩ (gain 24dB) 12kΩ (gain 30dB) 7.7kΩ (gain 34dB) |
| Protections | Overvoltage, undervoltage, overcurrent, overtemperature |
| General | |
| Power supply | 12V-30V DC |
| Dimensions | 350 x 920 x 350mm |
| Weight | 228g |
| Package | 1x TinySine TSA8802D Amplifier Module |
| Condition | New |
| Input | Optical RCA |
| Output | Screw terminals |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | TPA3321 |
| Power (W) | 100.0 |
