Bon à savoir
The Aune SC1 EVO is the brand's new high-performance external clock. This clock features an OXCO crystal oscillator designed in collaboration with Titan Audio Lab for extremely precise rendering. The device also features a new Vivid UI color interface for real-time monitoring of device performance.Including €0.05 for ecotax
Last items in stock!
- Paiement sécurisé
Ce qu'il fait
Aune SC1 EVO Clock OXCO 10MHz Sine / Square wave signal Silver
The Aune SC1 EVO is the brand's new high-performance master clock. This clock features an OXCO crystal oscillator designed in collaboration with Titan Audio Lab for extremely precise rendering. The device also features a new Vivid UI color interface for real-time monitoring of device performance. The Aune SC1 EVO features two 10M sine wave outputs and two 10M square wave outputs with phase synchronization of less than 0.00001°, ideal for connecting multiple devices. It can also be supplied from either DC or AC sources. Its power supply stage incorporates a low-noise, high-current LDO to provide a clean, stable electrical signal to the OCXO clock. This clock is ideal, for example, for use with the brand's S9C Pro headphone amplifier DAC.
Aune SC1 EVO overview
| 1 | Screen |
| 2 | Multifunction button |
| 3 | 2x 10Mhz sine signal output |
| 4 | 2x 10Mhz square wave output |
| 5 | DC9V power connector |
| 6 | Power on / Mains supply |
| Specifications | |
| Product type | Clock |
| Outputs | 2x 10Mhz sine signal output 2x 10Mhz square wave signal output |
| Frequency accuracy | +/- 50ppb |
| Frequency stability | < 0.01ppb |
| Output amplitude | Square wave signal ≥ 9dBm Sine wave signal ≥ 5dBm |
| Output impedance | 50 ohm |
| Close phase noise | -100dBc |
| Short-term stability | 2E-12 |
| Heating time | Basic 10min |
| General | |
| Power supply | 100-240VAC 9VDC 2A |
| Operating temperature | Normal operation: 0°C-50°C Optimum operation: 15°C-35°C |
| Dimensions | 288*211*63mm |
| Weight | 2kg |
| Color | Silver |
| Package | 1x Aune SC1 Evo Silver 1x Power cable |
| Condition | New |
| EAN13 | 6974802511467 |
