Audio Isolation Transformer Ground Loop RCA
Audio Transformer
Reference 13755
Bon à savoir
This stereo RCA isolation transformer isolates the audio signal in order to considerably reduce interference and therefore noise. This allows a large transmission distance to be achieved without distortion.
€45.90Tax incl.
Including €0.05 for ecotax
2 years warranty
Available now
  • Paiement sécurisé
Ce qu'il fait
Transformateur Audio d'Isolation Boucle de Masse RCA
This stereo RCA isolation transformer isolates the audio signal in order to considerably reduce interference and therefore noise. This allows a large transmission distance to be achieved without distortion. To do this, the circuit integrates a unique impedance conversion and spectrum isolation system with anti-EMI capabilities. In short, this product solves the problems of distortion and noise that can be caused by a long connection or a difference in electrical potential. A 4KV protection system (ESD) is also integrated, allowing to protect the devices connected to the insulator.
SpEcifications
Product type Isolation audio transformer
Frequency response 20Hz - 20kHz
Input / output impedance 600Ω
Insulation voltage 800V
Insulation resistante 100MΩ
THD < 0.5% (30Hz - 20kHz), 0.05% @ 1kHz
Crosstalk < 60dB (20Hz - 20kHz), < 70dB @ 1kHz
SNR > 95dB
Protections 4KV (ESD)
Housing material Brushed Aluminium
Dimensions 145 x 110 x 60mm
Weight 114g
Color Champagne
Condition New
Avis
Comments (2)
Grade 4.5/5
No customer reviews for the moment.
€45.90Audio Isolation Transformer...
