Binding Posts for 15mm wood panels (pair)
Binding Posts
To weldFemale15.0YesSpeaker terminalCopper AlloyGold
Reference 10602
€4.90Tax incl.
2 years warranty
Available now
  • Paiement sécurisé
Ce qu'il fait
This type of terminal block is mounted on a pvc or wood panel of thickness less than 15mm
They are usually used to connect speakers.
Features:/ Strong>
  • Gold Plated
  • External diameter 11mm
  • Panel Drilling Diameter: 4.7mm
  • Maximum Panel Thickness: 15mm
  • Diameter of the hole or inserts the wires: 4.75mm
  • Compatible with audio banana plugs (4mm)
  • Height out of the case: 21mm
Condition New
Mounting type To weld
Connectic Female
Max panel thickness (mm) 15.0
Accepts Banana Plugs Yes
Connector Speaker terminal
Contacts Material (Connector) Copper Alloy
Contacts Plating (Connector) Gold
Avis
Comments (6)
Grade 4.5/5
No customer reviews for the moment.
€4.90Binding Posts for 15mm wood...
