VIBORG BP-604 Binding Post Pure Copper Ø4.5mm (Set x4)
Binding Posts
To screw To weldFemale11.5YesSpeaker terminalCopperNone
Reference 12770
Bon à savoir
The Viborg BP-604 are very good terminal blocks, ideal for high quality DIY assemblies. Indeed, they integrate a pure copper conductor in order to offer an optimal signal conductivity.
€129.00Tax incl.
Including €0.01 for ecotax
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
VIBORG BP-604
Viborg BP-604 borniers
The Viborg BP-604 are very good terminal blocks, ideal for high quality DIY assemblies. Indeed, they integrate a pure copper conductor in order to offer an optimal signal conductivity. In this same perspective, in order to protect the audio signal as much as possible, the connectors are insulated with Nylon and Polycarbonate.
In addition, this model has a body based on carbon fiber, POM and copper alloy giving it a strong design.
Finally, on the practical side, the connectors accept banana plugs and mounting is facilitated since the cable can be held by a screw.
Conductor material Pure copper
Housing material Carbon fiber, POM, copper alloy
Insulation Nylon
Polycarbonate
Connection type To screw / To solder
Acceptable cable diameter 4.5mm
Drilling diameter 11.45mm
Housing dimensions 11.5 x 23.4mm
Total length 54mm
Condition New
Mounting type To screw
To weld
Connectic Female
Max panel thickness (mm) 11.5
Accepts Banana Plugs Yes
Connector Speaker terminal
Contacts Material (Connector) Copper
Contacts Plating (Connector) None
Avis
Comments (0)
No customer reviews for the moment.
€129.00VIBORG BP-604 Binding Post Pure...
