WBT-0763 Speaker Terminals Gold Plated (set x4)
Binding Posts
To weldFemaleN/AYesSpeaker terminalCopper AlloyGold
Reference 6861
Bon à savoir
WBT-0763 speaker terminal blocks are 24k gold-plated, multilayer polished for maximum resistance to corrosion and oxidation. They meet the most demanding signal transmission requirements, thanks to a meticulous overall design.
€189.00Tax incl.
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
WBT-0763 Speaker Terminals Midline Classic Gold-plated 24k (Set x4)
Photo of WBT-0763 speaker terminals
WBT-0763 speaker terminal are 24k gold-plated, multilayer polished for maximum resistance to corrosion and oxidation. They meet the most demanding signal transmission requirements, thanks to a meticulous overall design. In fact, they ensure a high level of contact pressure. All these features enable them to accept large cable cross-sections while maintaining excellent conductivity. An integrated clamping system protects the banana plug connection from accidental disconnection. Puzzle plates (mounting insulators) complete the package for simplified installation. These terminal blocks are part of the classic WBT range.
If you are using WBT-0735 for bi-wiring, and wish to combine them with WBT-0725 short-circuit bridges, the terminal blocks must be mounted separately, i.e. without the connecting tab. Make sure to maintain a minimum distance of 30 mm (terminal center to terminal center). The distance to the second pair of terminal blocks must be exactly 60 mm.
Zoom in on a WBT-0763 terminal block
Product type Speaker terminal
Conception Monobloc
Contact material Copper alloy
COntact plating 24k Gold
Compatibility Banana plugs 4mm
6 or 8mm spades
Bare crimped wire
Max. conductor cross-section External : 6mm² (9 AWG)
Internal : 10mm² (AWG 7)
Internal connection Crimping or soldering
Max. panel thickness From 0.1 to 10mm
Identification rings 2x red
2x white
Gross weight 225g
Package 4x WBT-0763 speaker terminals
Condition New
Mounting type To weld
Connectic Female
Max panel thickness (mm) N/A
Accepts Banana Plugs Yes
Connector Speaker terminal
Contacts Material (Connector) Copper Alloy
Contacts Plating (Connector) Gold
Avis
Comments (1)
Grade 5/5
No customer reviews for the moment.
€189.00WBT-0763 Speaker Terminals Gold...
