XANGSANE XS-T072 Gold-Plated Speaker Terminals (Set x4)
Binding Posts
To weldFemale7.0YesBanana / SpadeCopperGold
Reference 18157
Bon à savoir
Xangsane's XS-T072 speaker terminals are ideal for mounting on enclosures with a maximum thickness of 7mm and a minimum of 3mm. Connectors are made of gold-plated copper alloy for enhanced conductivity and resistance to corrosion and oxidation.€14.90Tax incl.
2 years warranty
Available now
- Paiement sécurisé
Ce qu'il fait
XANGSANE XS-T072
Xangsane's XS-T072 speaker terminals are ideal for mounting on enclosures with a maximum thickness of 7mm and a minimum of 3mm. Non-slip joints are provided for mounting. Connectors are made of gold-plated copper alloy for enhanced conductivity and resistance to corrosion and oxidation. Internal cable assembly is by soldering, while on the other side, these terminal blocks accept either spades (Ø6/8mm) or banana plugs (Ø4mm).
| Specifications | |
| Product type | Speaker terminals |
| Contact material | Copper alloy |
| Contact plating | Gold |
| Min. mounting panel thickness | 3mm |
| Max. mounting panel thickness | 7mm |
| Mounting screw thread | 8mm |
| Compatible connectors | Banana plugs (Ø4mm) Spades (Ø6/8mm) |
| Internal cable mounting | To weld |
| Identification rings | |
| General | |
| Total dimensions | 50 x Ø16mm |
| Package | Set x4 |
| Condition | New |
| Mounting type | To weld |
| Connectic | Female |
| Max panel thickness (mm) | 7.0 |
| Accepts Banana Plugs | Yes |
| Connector | Banana / Spade |
| Contacts Material (Connector) | Copper |
| Contacts Plating (Connector) | Gold |
Avis
Comments (0)
No customer reviews for the moment.
€14.90XANGSANE XS-T072 Gold-Plated...
