Bluetooth 5.0 CSR8675 aptX-HD DAC ES9018 24bit 48kHz Module
Bluetooth Modules & Wireless Reception
BluetoothPH 2.0mm XH 2.54mmES9018K2M96kHz2 (Stereo)
Reference 13863
Bon à savoir
This small and powerful DAC module is based on an ESS ES9018K2M conversion chip, allowing for quality signal decoding. A chip that has already proven itself on many products, renowned for the accuracy and richness of the audio message it delivers.
€54.90Tax incl.
2 years warranty
  • Paiement sécurisé
Ce qu'il fait
Module DAC ES9018 Bluetooth
DAC ES9018K2M Bluetooth 5.0 CSR8675 aptX-HD 24bit 48kHz
Module DAC ES9018 Bluetooth 5.0 CSR8675 aptX LDAC 24bit 96kHz
However, the main advantage of this module is most probably its Bluetooth 5.0 input, allowing you to stream your files remotely, directly from your smartphone. In addition, the integrated CSR8675 Bluetooth chip supports aptX and aptX-HD technologies, improving throughput and transmission stability. These protocols support sampling rates up to 24bit 48kHz. A Bluetooth antenna is also provided to increase the reception range of the module.
On the output side, this is done on two PH 2.0mm 3-pin connectors, an OPA2604AP AOP to amplify the output signal. This AOP is mounted on DIP8 and can therefore be modified according to your listening preferences.
Product type DAC Module
DAC Chip ES9018K2M
Input Bluetooth
Output 1x Stereo AUX
Bluetooth chip CSR8675
Bluetooth version 5.0
Supported Bluetooth technologies aptX, aptX-HD
Supportes sampling rate Up to 24bit 48kHz
Dimensions 67 x 33mm
Fixation holes spacing 56 x 27mm
Power supply 5-32V DC (Sold separately)
Package 1x Bluetooth ES9018 DAC module
2x PH 2.0mm to bare wires (3 wires) cable
1x PH 2.0mm to bare wires (2 wires) cable
1x SMA Antenna
1x U.FL to SMA Cable adapter
Condition New
Input Bluetooth
Output PH 2.0mm
XH 2.54mm
DAC / ADC Chip ES9018K2M
Max sampling rate 96kHz
Channel 2 (Stereo)
Avis
Comments (3)
Grade 4.33/5
No customer reviews for the moment.
€54.90Bluetooth 5.0 CSR8675 aptX-HD...
