TINYSINE AUDIOB I2S Bluetooth 5.0 Receiver Module QCC3008 aptX U.FL
Bluetooth Modules & Wireless Reception
Reference 20053
Bon à savoir
This Tinysine AudioB I2S Bluetooth receiver module is based on a Qualcomm QCC3008 chip. This enables it to support sampling rates of up to 16bit 48kHz and reliable, stable transmission via the aptX codec. It has a U-FL connector for connecting an external 2.4G antenna, and output is via I2S.
€12.90Tax incl.
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
Tinysine AudioB I2S Bluetooth 5.0 Receiver Module QCC3008 aptX U.FL
Tinysine AudioB I2S
This Tinysine AudioB I2S Bluetooth receiver module is based on a Qualcomm QCC3008 chip. This enables it to support sampling rates of up to 16bit 48kHz and reliable, stable transmission via the aptX codec. It has a U.FL connector for connecting an external 2.4G antenna, and output is via I2S. The module features two sets of 10 pins, each spaced 2mm apart from the others for easy integration into many types of DIY projects such as a Bluetooth amplifier or DAC.
Module pin correspondence table
Mounting diagram
Mounting diagram
Module dimensions
Technical charcateristics
Product type Bluetooth receiver module
Bluetooth chip QCC3008
Bluetooth version Bluetooth 5.0
Output I2S (left justified, 1bit delay)
Supported sample rates 16bit 48kHz
Supported Bluetooth codecs aptX, SBC, AAC
Power consumption 5mA @ 5V
Supported Bluetooth profiles HFP V1.6
HSP V1.2
A2DP V1.2
AVRCP v1.4
Smartphone application support
Package 1x Tinysine AudioB I2S Bluetooth Receiver Module
Condition New
Avis
Comments (0)
No customer reviews for the moment.
€12.90TINYSINE AUDIOB I2S Bluetooth...
