WONDOM AA-AA11435 Package Functional Cables for BRB3 Module
Bluetooth Modules & Wireless Reception
NCNC
Reference 18563
Bon à savoir
This Wondom AA-AA11435 functional cable pack is specially designed for use with the Wondom AA-AB3116 (BRB3) Bluetooth receiver module.
€4.50Tax incl.
2 years warranty
Available now
  • Paiement sécurisé
Ce qu'il fait
WONDOM AA-AA11435 Package Functional cables for BRB3 module
WONDOM AA-AA11435 pack photo
This Wondom AA-AA11435 functional cable pack is specially designed for use with the Wondom AA-AB3116 (BRB3) Bluetooth receiver module. It includes one Bluetooth antenna, one Bluetooth pairing cancellation cable, one Jack 3.5mm line out cable, one PH-4pins power cable, one speaker output cable and one Bluetooth LED indicator cable. All this wiring will enable you to make full use of Wondom's AA-AB3116 (BRB3) module.
Wiring diagram for Wondom module AA-AB41136
WONDOM AA-AA11435 pack connection diagram with AA-AB3116 module (BRB3)
Bluetooth Antenna
1. Bluetooth antenna
External Bluetooth antenna via U.FL connector.
2. Bluetooth pairing cancellation cable
This Bluetooth pairing cancellation cable has a button and a 2-pin connector. Simply press the button once to cancel pairing.
3.5mm jack line output cable
3. 3.5mm jack line output cable
This cable has a 3.5mm jack connector. It allows connection to an amplifier, for example.
PH-4Pos power cable
4. PH-4Pos power cable
This discharge cable is used to power the Wondom AA-AB3116 (BRB3) module with a Wondom BCPB module.
Speaker output cable
5. Speaker output cable
2x 3W speaker output via bare wires.
6. Bluetooth LED indicator cable
Bluetooth status indicator LED for Wondom AA-AB3116 (BRB3) module.
Condition New
Input NC
Output NC
Avis
Comments (0)
No customer reviews for the moment.
€4.50WONDOM AA-AA11435 Package...
