RAMM AUDIO GENESIS7 Interconnect Cable RCA-RCA Graphene OCC Copper 1m (Pair)
Cables RCA RCA
Reference 19928
Bon à savoir
The Ramm Audio Genesis7 interconnect cable is an RCA interconnect cable featuring high quality construction and materials. It features 3 main conductors made up of 3 strands of 0.5mm monocrystalline graphene OCC copper for excellent signal transmission, with a conductivity level 40% higher than standard copper conductors.Including €0.05 for ecotax
Last items in stock!
- Paiement sécurisé
Ce qu'il fait
RAMM Audio Genesis7 Interconnect Cable RCA-RCA Graphene OCC Copper 1m (Pair)
The Ramm Audio Genesis7 interconnect cable is an RCA interconnect cable featuring high quality construction and materials. It features 3 main conductors made up of 3 strands of 0.5mm monocrystalline graphene OCC copper for excellent signal transmission, with a conductivity level 40% higher than standard copper conductors. A drain wire with three 0.5mm OCC copper conductors completes the assembly for grounding. This modulation cable also features AL Mylar aluminum multi-layer shielding, which effectively protects against EMI/RFI interference and reduces noise levels. The brand's proprietary Air Inside Geometry technology is also present, eliminating the effects of distortion. The Ramm Audio Genesis7 is sure to meet the expectations of demanding audiophiles.
RAMM AUDIO Genesis7: 30891GT RCA connectors
Ramm Audio 30891GT RCA connectors feature gold-plated tellurium copper alloy contacts for enhanced resistance to corrosion and oxidation. Their shell is made of non-magnetic aluminum, and each contact is individually isolated for protection against interference. In addition, these connectors offer a pleasing, high-end aesthetic thanks to their black color and two stripes revealing the gold plating.
RAMM AUDIO Genesis7 cable structure
| 1 | Braided Nylon |
| 2 | PVC sheath |
| 3 | Cotton filler |
| 4 | Polypropylene rods |
| 5 | Graphene OCC copper |
| 6 | Al Mylar |
| 7 | OCC wires |
| Specifications | |
| Product type | RCA-RCA interconnect cable |
| Connectors | RCA male 30891GT |
| Length | 1m |
| Cable conductor material | Graphene OCC copper |
| Cross-section | 3x 1mm² |
| Shielding | Al Mylar |
| Insulation | Polypropylene + Cotton filler + PVC |
| External diameter | Ø9.3mm |
| electrical characteristics | |
| Inductance | 1.4μh/m per conductors |
| Resistance | 0.03Ω/m per conductors |
| Capacitance | 184pF/m per conductors |
| General | |
| Weight | 115g / cable |
| Package | Sold by pair |
| Condition | New |
