SHANLING EC ZERO T CD Player on Battery R2R JAN6418 Bluetooth 5.3
CD Players
Reference 20774
Bon à savoir
With the EC Zero T, Shanling presents a top-of-the-range CD player featuring R2R digital/analogue conversion and amplification based on JAN6418 power tubes, offering smooth, warm sound reproduction with a typically analogue timbre.
€589.00Tax incl.
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
Shanling EC Zero T CD Player on Battery R2R JAN6418 Bluetooth 5.3
Shanling EC Zero T : Front view
Shanling EC Zero T: Exceptionally stable servo architecture
The Shanling EC Zero T benefits from a meticulous design using an active magnetic fixing system to continuously adjust the pressure on the disc, offering exceptional stability during rotation and greatly reducing the noise caused by CD vibrations. In addition, the EC Zero T is equipped with an anti-shake system so that you can follow it everywhere without the risk of the CD jumping, plus a playback head with a gapless function.
Shanling EC Zero T : In use
Shanling EC Zero T: DAC R2R
For its digital/analogue conversion stage, the EC Zero T opts for an R2R ladder resistor network, using a total of 192 resistors in a 24-bit architecture to deliver the finest possible sound reproduction. In addition, this CD player features a NOS (Non-Oversampling) and OS (Oversampling) mode, allowing you to personalise your listening experience to suit your tastes.
Shanling EC Zero T : Signal processing diagram
Shanling EC Zero T : JAN6418 tubes
Shanling EC Zero T: Power tube amplification
The EC Zero T's amplification stage is based on a pair of TPA6120 OPA coupled to JAN6418 power tubes, renowned for their compact size, low power consumption and operating stability. The use of power tubes provides warm, soft sound reproduction, but if you want a more neutral reproduction with more pronounced dynamics, a transistor amplification mode is also available.
Shanling EC Zero T: 5500mAh battery
To keep you on the move, the EC Zero T is equipped with a 5500mAh battery capable of providing 8 hours of uninterrupted listening when used via the 3.5mm jack output, and up to 20 hours when used via Bluetooth. It's easy to recharge using the USB-C port.
Shanling EC Zero T : Rear panel connectors
Shanling EC Zero T: Extensive connectivity
Thanks to its wide choice of connectors, the EC Zero T is capable of integrating a large number of different configurations. In addition to 3.5mm and 4.4mm headphone outputs, this CD player also has 3.5mm and 4.4mm line outputs and an optical coaxial SPDIF output. In addition, the EC Zero T incorporates Bluetooth 5.3 connectivity supporting aptx Adaptive, aptx and SBC protocols. This wide choice of connections means you can use it directly with headphones or earphones, wireless or not, or integrate it into a more complex audio system and connect it directly to a power amplifier or DAC.
Shanling EC Zero T: Robust aesthetics
In terms of aesthetics, the EC Zero T has a retro design that includes a number of physical buttons and a volume slider, all housed in a tempered glass and CNC-machined aluminium case that guarantees unfailing durability.
Shanling EC Zero T : components machined before assembly
Shanling EC Zero T overview
Shanling EC Zero T : Descriptive diagram of the various functions
1 Stop
2 Play / Pause
3 Function selector
4 Previous track
5 Next track
6 Lock button
7 Line output 4.4mm jack
8 Line output 3.5mm jack
9 SPDIF Coaxial / Optical output
10 Bluetooth receiver
11 USB-C DAC input
12 USB-C power supply port
13 Power mode switch
Product type Lecteur CD
Input 1x USB-C DAC input
Outputs 1x Single-ended 3.5mm jack headphone output
1x Balanced 4.4mm jack headphone output
1x Single-ended 3.5mm jack line output
1x Balanced 4.4mm jack line output
1x SPDIF Coaxial / Optical output
Bluetooth
DAC R2R 24 bit
USB DAC support PCM up to 32bit 768kHz
DSD up to DSD512
Screen LCD 1.68"
Digital filter NOS
OS
Bluetooth version 5.3
Supported Bluetooth codecs aptX Adaptive
aptX
SBC
Transistor mode output power Low gain: 57mW @ 32Ω
High gain: 158mW @ 32Ω
High gain (external power supply): 330mW @ 32Ω
Tube mode output power Low gain: 47mW @ 32Ω
High gain (external power supply): 268mW @ 32Ω
Total harmonic distortion more noise (THD+N) 0.02%
Dynamic range 116dB
Channel separation 79dB
Signal-to-noise ratio (SNR) 115dB
Noise (Low gain) 111dB
Frequency response 20Hz-40kHz (-0.5dB)
Output impedance 4.7Ω
Transistor mode output power Low gain: 195mW @ 32Ω
High gain: 551mW @ 32Ω
High gain (external power supply): 1220mW @ 32Ω
Tube mode output power Low gain: 195mW @ 32Ω
High gain (external power supply): 1087mW @ 32Ω
Dynamic range 117dB
Channel separation 103dB
Signal-to-noise ratio (SNR) 117dB
Noise (Low gain) 108dB
Output impedance 6.6Ω
Single-ended Line output 3.5mm jack
Transistor mode output level 2.12Vrms
Tube mode output level 1.97Vrms
Signal-to-noise ratio (SNR) 116dB
Balanced Line output 4.4mm jack
Transistor mode output level 4.2Vrms
Tube mode output level 3.94Vrms
Signal-to-noise ratio (SNR) 118dB
Power supply 5V / 2A
Dimensions 158 x 150 x 28mm
Weight 669g
Color Black
Package 1x Shanling EC Zero T
1x USB-A to USB-C cable
Condition New
EAN13 6972835393074
Avis
Comments (0)
No customer reviews for the moment.
€589.00SHANLING EC ZERO T CD Player on...
