Bon à savoir
With its SCD1.3, Shanling unveils a high-end SACD CD player featuring the AKM AK4499EX + AK4191EQ DAC chip combo, XMOS XU316 USB interface and TPA6120 headphone amplification. Multifunctional, the Shanling SCD1.3 offers many other possibilities in terms of Hi-Fi configuration.Including €0.05 for ecotax
Last items in stock!
- Paiement sécurisé
Ce qu'il fait
SHANLING SCD1.3 CD SACD Player DAC AKM4499EX + AKM4191EQ Black
With its SCD1.3, Shanling unveils a high-end SACD CD player featuring the AKM AK4499EX + AK4191EQ DAC chip combo, XMOS XU316 USB interface and TPA6120 headphone amplification. Multifunctional, the Shanling SCD1.3 offers many other possibilities in terms of Hi-Fi configuration. In fact, it features Bluetooth functionality, a USB-A U-Disk port and supports DLNA and AirPlay for network connection. These additional features make it easy to integrate into any sound system. Moreover, it features numerous inputs and outputs. Inputs include USB-B, coaxial SPDIF and Toslink optical, while digital outputs include I2S via HDMI, coaxial SPDIF and Toslink optical. Two analog outputs are also available: an analog RCA output and a balanced XLR output.
Shanling SCD1.3: MediaTek ME1389EE playback system and Sanyo HD870 laser
The SCD1.3's CD playback system enables it to fully exploit the capabilities of both high-resolution SACD and standard CD discs. It is equipped with a MediaTek ME1389EE drive and a Sanyo HD870 laser head offering excellent performance.
Shanling SCD1.3: AKM AK4499EX and AK4191EQ chip combo
The SCD1.3's AKM chip combo enables it to render highly detailed sound over a wide soundstage, while retaining Shanling's soft, warm sound signature. In addition, a high-precision MUSES8902 volume controller enables the SCD1.3 to be directly associated with a power amplifier or active loudspeakers.
Shanling SCD1.3: XMOS XU316 USB interface
If you want higher-resolution streams than SACD format, you can always use the USB-B input and the XMOS XU316 USB interface, which supports up to PCM 32 bit 768 kHz and DSD512.
Shanling SCD1.3: 3 digital outputs
The Shanling SCD1.3 incorporates three digital outputs, allowing it to be paired with a more powerful DAC if desired. The I2S output via HDMI is FGPA-optimized and directly compatible with 10 different HDMI I2S pinouts. The SPDIF and optical coaxial outputs also enable simplified connection to a DAC. SACD disc playback will be converted to 88.2kHz on its digital outputs.
SHANLING SCD1.3: MTouch touchscreen and Bluetooth functionality
The SCD1.3's 5" touchscreen uses Shanling's Mtouch technology and an Ingenic X2000 processor for smooth, precise touch navigation. It's also thanks to Shanling's Mtouch technology that the SCD1.3 benefits from Bluetooth 5.0 functionality, Wi-Fi connectivity and support for DLNA, AirPlay and NAS protocols. Bluetooth 5.0 enables the SC1.3 to support high-resolution Bluetooth codecs such as SBC, AAC, aptX HD and LDAC.
Shanling SCD1.3 overview
| 1 | CD / SACD player |
| 2 | 5" touch screen |
| 3 | Switch CD / SACD |
| 4 | Standby / volume control |
| 5 | Stop / Eject |
| 6 | Play / pause |
| 7 | Previous |
| 8 | Next |
| 9 | Remote control signal reception |
| 10 | 6.35mm headphone output |
| 11 | USB-A port (U-Disk) |
| 12 | Digital outputs: I2S HDMI / SPDIF Coaxial / Optical Toslink |
| 13 | Analog outputs: stereo RCA / balanced stereo XLR |
| 14 | Digital inputs: USB-B / SPDIF coaxial / Optical Toslink |
| 15 | Antenne Bluetooth / WiFi |
| 16 | IEC power supply |
| Specifications | |
| Product type | CD SACD player / DAC |
| Inputs | CD/SACD 1x USB-B 1x SPDIF coaxial 1x Optical Toslink 1x USB-A (U-disk) Bluetooth Wi-Fi |
| Outputs | 1x RCA stereo output 1x XLR balanced stereo output 1x I2S output via HDMI 1x SPDIF coaxial output 1x Toslink optical output 1x 6.35mm headphone output |
| DAC chip | AKM AK4499EX + AK4191EQ |
| USB interface | XMOS XU316 |
| Headphone amplifier chip | TPA6120 |
| Supported Bluetooth codecs | SBC, ACC, aptX, aptX HD, LDAC |
| Supported sampling rates | SACD : 88.2kHz USB : 32bit 768kHz DSD512 |
| RCA OUTPUT MEASUREMENT | |
| Output level | 2.5Vrms |
| Frequency response | 20Hz-40kHz (-0.1dB) |
| THD+N | 0.0005% |
| Dynamic range | 119dB |
| SNR | 119dB |
| XLR OUTPUT MEASUREMENT | |
| Niveau de sortie | 5Vrms |
| Output level | 20Hz-40kHz (-0.1dB) |
| THD+N | 0.0005% |
| Dynamic range | 122dB |
| SNR | 122dB |
| 6.35MM jack HEADPHONE OUTPUT MEASUREMENTS | |
| Output power | 1.1 W @ 32Ω 153mW @ 300Ω |
| THD+N | 0.001% |
| Channel separation | 75dB@32Ω |
| SNR | 122dB |
| Output impedance | 4.7Ω |
| General | |
| Dimensions | 280 x 280 x 96mm |
| Weight | 6.6kg |
| Color | Black |
| Package | 1x Shanling SCD1.3 CD/SACD Player DAC 1x Power cable |
| Condition | New |
| EAN13 | 6972835392121 |
