THINKYA DVR108 CD Player DAC ES9038Q2M 32bit 768kHz DSD512 Bluetooth 5.1
CD Players
Reference 20932
Bon à savoir
Thinkya's DRV108 is a full-featured CD player and DAC that uses a TMC688 processor and ES9038Q2M DAC chip to upsample CDs up to PCM 384kHz and convert digital signals up to PCM 768kHz and DSD512. The DRV108 also benefits from Bluetooth 5.1 bi-directional connectivity, allowing you to enjoy the convenience of a wireless connection, whatever your system configuration.
€229.00Tax incl.
Including €0.05 for ecotax
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
Thinkya DRV108 CD Player DAC ES9038Q2M 32bit 768kHz DSD512 Bluetooth 5.1
Thinkya DRV108 : Front view
Thinkya
's DRV108
Thinkya DRV108: Extensive connectivity
The DRV108 offers a wide range of connectivity options. It features XLR and RCA outputs on the analog side, as well as Toslink optical and coaxial on the digital side. But that's not all: this CD player also features a 3.5mm headphone output on the front panel, amplified by a TPA152 chip. On the digital input side, two USB-A ports are available, one for a USB drive, the other for a signal from an external device. Finally, the DRV108 is also equipped with Bluetooth 5.1 bi-directional connectivity for wireless use.
Thinkya DRV108 : Bi-Directional Bluetooth connection
Thinkya DRV108 : 3/4 view
Thinkya DRV108: ES9038Q2M DAC
To deliver the highest-quality digital-to-analog conversion possible, the DRV108 relies on an ES9038Q2M chip, handling signals up to PCM 32bit 768kHz and DSD512, and offering oversampling from CD 44.1kHz to 384kHz. The choice of ESS's DAC chip also ensures crystal-clear sound reproduction, devoid of any parasitic noise or distortion. Indeed, the DRV108 boasts a dynamic range of 133dB, an impressive signal-to-noise ratio of 129dB and distortion of -120dB.
Product type CD Player
DAC
Processor TMC688
Inputs CD Player
1x USB-A (USB Disk up to 32Go)
1x USB-A (USB-DAC)
Bluetooth
Outputs 1x Optical Toslink
1x Coaxial
1x Single-ended stereo RCA
1x Balanced stereo XLR
1x Jack 3.5mm headphone output
Bluetooth
Bluetooth version Bluetooth 5.1 bidirectional
Supported formats WAV / FLAC / APE / MP3 / WMA
Supported sampling rates PCM up to 32bit 768kHz
Native DSD up to DSD512
Total harmonic distortion (THD) 0.05%
Signal-to-noise ratio (SNR) > 90dB
Headphone output power 2x50mW @ 32Ω
Output level XLR: 3.5V
RCA: 1.5V
Power supply 50Hz 220V AC
Consumption 40W
Dimensions 360 x 147 x 210mm
Weight 4.1kg
Color Silver
Package 1x Thinkya DRV108
1x Infrared remote control
1x Bluetooth antenna
Condition New
EAN13 6973595030674
Avis
Comments (0)
No customer reviews for the moment.
€229.00THINKYA DVR108 CD Player DAC...
