VIBORG VB1620G Cable Crimping Tips with Insulation 24k Gold-Plated Copper 16mm² (Set x10)
Crimp Sleeves
5.816.0CopperGold
Reference 19048
Bon à savoir
These Viborg VB1620G crimping tips for cable are very useful when connecting cables to connectors, for example. They enable the pressure of the mounting screw to be exerted on the crimp, rather than directly on the stranded conductors.
€12.90Tax incl.
2 years warranty
Available now
  • Paiement sécurisé
Ce qu'il fait
Viborg VB1620G Crimping Tips photo
These Viborg VB1620G crimping tips for cable are very useful when connecting cables to connectors, for example. They enable the pressure of the mounting screw to be exerted on the crimp, rather than directly on the stranded conductors. They can also be used to assemble two sets of cables. High-quality, they are made of 24K gold-plated copper for optimum resistance to oxidation and corrosion. They are available in several sizes for different cable cross-sections. Assembly is carried out using suitable crimping tool.
Crimping tips dimensions
Product type Crimping tips for cable
Body material Pure copper
Plating 24k Gold
Insulation PTFE
Compatible cable cross-section 16mm² (AWG5)
Total length 26mm
Internal diameter Ø5.8mm
Package x10
Condition New
Max cable diameter (mm) 5.8
Section (mm²) 16.0
Contacts Material (Connector) Copper
Contacts Plating (Connector) Gold
Avis
Comments (0)
No customer reviews for the moment.
€12.90VIBORG VB1620G Cable Crimping...
