VIBORG VB4018G Cable Crimping Tips with Insulation 24k Gold-Plated Copper 4mm² (Set x10)
Crimp Sleeves
2.84.00CopperGold
Reference 19042
Bon à savoir
These Viborg VB4018G crimping tips for cable are very useful when connecting cables to connectors, for example. They enable the pressure of the mounting screw to be exerted on the crimp, rather than directly on the stranded conductors.€18.90Tax incl.
2 years warranty
Last items in stock!
- Paiement sécurisé
Ce qu'il fait
These Viborg VB4018G crimping tips for cable are very useful when connecting cables to connectors, for example. They enable the pressure of the mounting screw to be exerted on the crimp, rather than directly on the stranded conductors. They can also be used to assemble two sets of cables. High-quality, they are made of 24K gold-plated copper for optimum resistance to oxidation and corrosion. They are available in several sizes for different cable cross-sections. Assembly is carried out using suitable crimping tool.
| Specifications | |
| Product type | Crimping tips for cable |
| Body material | Pure copper |
| Plating | 24k Gold |
| Insulation | PTFE |
| Compatible cable cross-section | 4mm² (AWG12) |
| General | |
| Total length | 24mm |
| Internal diameter | Ø2.8mm |
| Package | x10 |
| Condition | New |
| Max cable diameter (mm) | 2.8 |
| Section (mm²) | 4.00 |
| Contacts Material (Connector) | Copper |
| Contacts Plating (Connector) | Gold |
Avis
Comments (0)
No customer reviews for the moment.
€18.90VIBORG VB4018G Cable Crimping...
