VIBORG VB6018R Cable Crimping Tips with Insulation OFC / Silver / Rhodium Plated Copper 6mm² (Set x10)
Crimp Sleeves
3.56.00CopperRhodium Silver
Reference 19053
Bon à savoir
These Viborg VB6018R crimping tips for cable are very useful when connecting cables to connectors, for example. They enable the pressure of the mounting screw to be exerted on the crimp, rather than directly on the stranded conductors.
€23.90Tax incl.
2 years warranty
Available now
  • Paiement sécurisé
Ce qu'il fait
VIBORG VB6018RCable Crimping Tips with Insulation OFC / Silver / Rhodium Plated Copper 6mm² (Set x10)
Viborg VB6018R Crimping Tips photo
These Viborg VB6018R crimping tips for cable are very useful when connecting cables to connectors, for example. They enable the pressure of the mounting screw to be exerted on the crimp, rather than directly on the stranded conductors. They can also be used to assemble two sets of cables. High-quality, they are made of copper with triple plating layer of OFC / Silver / Rhodium for optimum resistance to oxidation and corrosion. They are available in several sizes for different cable cross-sections. Assembly is carried out using suitable crimping tool.
Crimping tips dimensions
Product type Crimping tips for cable
Body material Pure copper
Plating OFC / Silver / Rhodium
Insulation PTFE
Compatible cable cross-section 6mm² (AWG10)
Total length 24mm
Internal diameter Ø3.5mm
Package x10
Condition New
Max cable diameter (mm) 3.5
Section (mm²) 6.00
Contacts Material (Connector) Copper
Contacts Plating (Connector) Rhodium
Silver
Avis
Comments (0)
No customer reviews for the moment.
€23.90VIBORG VB6018R Cable Crimping...
