AUDIOPHONICS I-Sabre DAC ES9023 TCXO Raspberry Pi
DAC and Interface Modules
I2SScrew terminalsES9023192kHz2 (Stereo)
Reference 10296
€29.90Tax incl.
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
Following the success of the Sabre ES9023 in I2S version to analog, we decided to market a more advanced version equipped with an improved connector facilitating its use (no soldering required).
Thistte upgrade now has a TCXO full size clock.
Converter with an unbeatable price / quality ratio with direct analog outputs on high quality headers, this module is ideal for transforming a Raspberry Pi A +, B + or 2.0 / 3.0 into a high-definition file player.
Equipped with the now famous SABRE ES9023 (equipped with our U-SABRE), Ultra low noise "ON" regulator and condenser OS-CON this DAC will offer you musical sound and rich micro details.
Its high versatility (GPIO B + or A + format HAT (for PI) as well as I2S inputs) allows it to be also usable from a USB interface or any I2S source.
Features:
  • I2S input on 5 pin XHP connector
  • 5 V input on 2-pin XHP connector (not required if the PI is powered by the Micro USB port)
  • Input: Raspberry Pi 40PIN GPIO
  • GPIO report (you can stack other modules)
  • Output: RCA High Quality Gold Plated
  • Supported sampling rates: 24bit 192 kHz
  • Clock TCXO 50MHZ 0.5ppm
  • No welding required
  • Supplied with 4 nuts, 4 screws and 4 spacersused to fix it on the PI B +, A + or 2.0 (HAT format)
  • Spacing: 50 x 50 mm
  • PCB Dimensions: 65x56x30mm
  • I2S driver: Hifiberry DAC
  • Volume fixed under Volumio in bitperfect
Can be used with:
http://www.audiophonics.fr/images2/picoreplayer.jpg
Illustration with a Raspberry Pi 2:
Condition New
Input I2S
Output Screw terminals
DAC / ADC Chip ES9023
Max sampling rate 192kHz
Channel 2 (Stereo)
EAN13 3052350671772
Avis
Comments (15)
Grade 4.93/5
No customer reviews for the moment.
€29.90AUDIOPHONICS I-Sabre DAC ES9023...
