DAC PCM5102 I2S 32bit/384kHz Raspberry PI
DAC and Interface Modules
I2SRCAPCM5102384kHz2 (Stereo)
Reference 10551
€9.90Tax incl.
Including €0.01 for ecotax
2 years warranty
Available now
- Paiement sécurisé
Ce qu'il fait
Here is a modern converter allowing to have a quality analog output from any I2S source (for example a Raspberry PI or other SOC with I2S outputs included).
Based on a PCM5102A capable of converting sampling rates up to 32 bit / 384 kHz it will allow you to realize very simply a high-end audio player at very low price.
Although intended to be used with a PI nothing prohibits to consider its use in I2S by means of an interface like Amanero, XMOS, CM6631A etc ...
Features:
- Texas Instruments PCM 5102 A Converter (SNR: 112 db, Distortion -93dB)
- Inputs: I2S (Select justification by jumper (left justified).)
- Power Supply: 5V - 10V DC
- Outputs: Stereo RCA (2.1 V rms to 1K ohm)
- PCB Dimensions: 48 x 48mm
- Center distance: 43 x 43mm
- Weight: 20g
| Condition | New |
| Input | I2S |
| Output | RCA |
| DAC / ADC Chip | PCM5102 |
| Max sampling rate | 384kHz |
| Channel | 2 (Stereo) |
Avis
Comments (4)
Grade
No customer reviews for the moment.
€9.90DAC PCM5102 I2S 32bit/384kHz...
