DAC Board CS4398 CS8416 24bit 192kHz
DAC Modules
Optical
SPDIFRCA
XH 2.54mmCS4398192kHz
Reference 16528
Bon à savoir
This DAC module will allow you to enjoy a digital to analog conversion at a low price and ideal for integration in a DIY project. Its conversion stage is based on a CS4398 DAC chip, supporting PCM audio streams up to 24bit 192kHz. SPDIF reception is provided by a CS8416 chip. The module also integrates a NE5532P AOP on its output stage, mounted on DIP8 and therefore easily interchangeable.€24.90Tax incl.
2 years warranty
Last items in stock!
- Paiement sécurisé
Ce qu'il fait
DAC Board
For the connectic, we find in input Toslink optical and coaxial. For the outputs, the module provides stereo RCA and a second analog output on XH2.54mm 3 pins connector.
| Specifications | |
| Product type | DAC Board |
| DAC Chip | CS4398 |
| SPDIF Receiver | CS8416 |
| Inputs | 1x Optical Toslink 1x Coaxial |
| Outputs | 1x Stereo RCA 1x XH2.54mm 3 pins |
| Supported sampling rates | PCM up to 24bit 192kHz |
| SNR | > 120dB |
| Dynamic range | > 120dB |
| THD+N | -107dB |
| General | |
| Supply voltage | Double 12VAC |
| Dimensions | 82 x 50 x 22mm |
| Weight | 40g |
| Condition | New |
| Input | Optical SPDIF |
| Output | RCA XH 2.54mm |
| DAC / ADC Chip | CS4398 |
| Max sampling rate | 192kHz |
Avis
Comments (0)
No customer reviews for the moment.
€24.90DAC Board CS4398 CS8416 24bit...
