DAC Module MS8413 SPDIF Coaxial Optical 24bit 192kHz
DAC Modules
Optical SPDIFJack 3.5mm RCAMS8413192kHz
Reference 18641
Bon à savoir
This small, affordable DAC module is equipped with an MS8413 digital-to-analog conversion chip and supports PCM audio streams up to 24bit 192kHz. On the input side, the module features a coaxial jack and a Toslink optical port. Output can be either RCA or 3.5mm jack.
€7.90Tax incl.
2 years warranty
Available now
  • Paiement sécurisé
Ce qu'il fait
DAC module MS8413
MS8413 DAC module connection diagram
1 USB-C power input
2 Coaxial input
3 Optical input
4 Jack 3.5mm line output
5 AUX RCA output
Product type DAC board
DAC chip MS8413
Inputs 1x Optical Toslink
1x Coaxial
Outputs 1x Jack 3.5mm line output
1x AUX stereo RCA output
Supported sampling rates PCM up to 24bit 192kHz
Distorsion 0.001%
Supply voltage 5VDC via USB-C (power supply not included)
PCB dimensions 61 x 57mm
Total dimensions 61 x 76mm
Condition New
Input Optical
SPDIF
Output Jack 3.5mm
RCA
DAC / ADC Chip MS8413
Max sampling rate 192kHz
Avis
Comments (1)
Grade 5/5
No customer reviews for the moment.
€7.90DAC Module MS8413 SPDIF Coaxial...
