SMSL M20 DAC Headphone Amplifier 4xCS43131 XMOS XU316 TPA6120A2 32bit 768kHz DSD256 Silver
DAC with volume
Reference 20758
Bon à savoir
The SMSL M20 DAC headphone amplifier benefits from audiophile components and a most singular form factor. It features no less than 4 CS43131 chips and an XMOS XU316 USB interface, enabling it to support sampling rates up to PCM 32bit 768kHz, DSD256 and MQA.
€149.00Tax incl.
Including €0.05 for ecotax
2 years warranty
  • Paiement sécurisé
Ce qu'il fait
Photo of SMSL M20
The SMSL M20 DAC / headphone amplifier benefits from audiophile components and a most singular form factor. It features no less than 4 CS43131 chips and an XMOS XU316 USB interface, enabling it to support sampling rates up to PCM 32bit 768kHz, DSD256 and MQA. On the headphone amplification side, the TPA6120A2 delivers 2x700mW under 16 ohm and up to 2x40mw under 600 ohm. The SMSL M20 is therefore capable of driving many of the headphones and IEMs available on the market. Connectivity includes a USB-C input (2.0/1.1), a stereo line output on 3.5mm jack and, of course, two headphones outputs: 3.5mm jack and balanced 4.4mm jack.
SMSL M20 highlights
SMSL M20: A low-noise, high-power device
The SMSL M20 integrates a low-noise power supply that powers various audiophile components, whether for its digital-to-analog conversion stage or its headphones amplification stage. In addition to supporting high-resolution streams thanks to no fewer than 4 CS43131 chips, TPA6120A2 headphone amplifier chips enable it to drive audio headphones or IEMs with impedances ranging from 16 ohms to 600 ohms.
Photo of SMSL M20 TPA6120A2 chips
SMSL M20 output power table
16 ohm 700mW
32 ohm 700 mW
64 ohm 350mW
150 ohm 160mW
300 ohm 80mW
600 ohm 40mW
La compatibilité du SMSL M20
SMSL M20: Extended compatibility
The M20's USB-C input can operate in either USB 2.0 or USB 1.1 mode, providing an optimum level of compatibility with a wide range of devices, from computers and smartphones to video game consoles such as the PS5 and Nintendo Switch.
SMSL M20: A device with singular aesthetics
The SMSL M20's attractive tempered-glass panel reveals all its circuitry. Moreover, its hyper-compact form factor enables it to fit easily into any space.
SMSL M20 aesthetics
SMSL M20 overview
SMSL M20 overview
1 Operating mode selection
2 Volume +
3 Volume -
4 USB-C input
5 USB-C power port
6 3.5mm line output jack
7 3.5mm headphone output
8 Balanced 4.4mm headphone output
Product type DAC Headphone amplifier
DAC chip 4x CS43131
Headphone amplifier chips 2x TPA6120A2
Inputs 1x USB-C input
Outputs 1x 3.5mm jack output
1x 3.5mm jack single-ended headphone output
1x 4.4mm jack balanced headphone output
Supported sample rates PCM up to 32bit 768kHz
DSD up to DSD256
Headphone output power 700mW @ 16Ω
700mW @ 32Ω
350mW @ 64Ω
160mW @ 150Ω
80mW @ 300Ω
40mW @ 600Ω
Output level 3.5mm jack line output: 2.5Vrms
3.5mm jack headphone output: 2.5Vrms
4.4mm jack headphone output: 5Vrms
Output impedance Line: 22 ohm
Headphones: Near 0 ohm
Dynamic range Jack 3.5mm: 119dB
Jack 4.4mm: 124dB
SNR Jack 3.5mm: 119dB
Jack 4.4mm: 124dB
THD+N 0.0001% (-115 dB)
USB compatibility Windows 7/8/8.1/10/11, Android, iOS, macOS 10.6+, Linux
PS5, Nintendo Switch
PCM filters x5
Power supply 5V 1A via USB-C
Energy consumption < 15 W
Standby: < 0.5 W
Dimensions 85 x 22.5 x 85 mm
Weight 165g
Color Silver
Package 1x SMSL M20
1x USB-A to USB-C cable
1x USB-C to USB-C cable
Condition New
EAN13 6970141850083
Avis
Comments (0)
No customer reviews for the moment.
€149.00SMSL M20 DAC Headphone...
