SMSL RAW PRO-DAC1 DAC ES9039MSPRO Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 MQA-CD
DAC with volume
Reference 20227
Bon à savoir
The SMSL RAW PRO-DAC1 is a precise, high-performance DAC based on an ESS ES9039MSPRO DAC chip and a USB XMOS XU-316 interface. It can therefore support high-resolution sampling rates up to PCM 32bit 768kHz, DSD512 and MQA/MQA-CD.Including €0.05 for ecotax
Last items in stock!
- Paiement sécurisé
Ce qu'il fait
The SMSL RAW PRO-DAC1 is a precise, high-performance DAC based on an ESS ES9039MSPRO DAC chip and a USB XMOS XU-316 interface. It can therefore support high-resolution sampling rates up to PCM 32bit 768kHz, DSD512 and MQA/MQA-CD. In addition, it features Bluetooth functionality thanks to the latest Qualcomm QCC5125 chip supporting aptX HD and LDAC (24bit/96kHz) codecs for extremely reliable wireless transmission. The performance of the SMSL RAW PRO-DAC1 is made possible by its optimized Accu Silicon clock circuit and low-noise power supply. In terms of appearance, we find the slim, elegant lines that characterize SMSL products, but also a beautiful color display that facilitates the user experience. As for connectivity, there's a full range of digital inputs, including USB-C, USB-B, Toslink optical, SPDIF coaxial, AES/EBU and I2S via HDMI.
SMSL RAW PRO-DAC1: ES9039MSPRO DAC chip and XMOS XU-316 USB interface
The SMSL RAW PRO-DAC1 is based on high-quality Hi-Fi components such as the ES9039MSPRO DAC chip and an XMOS XU316 interface. This enables it to support high-resolution sampling rates up to PCM 32bit 768kHz, DSD512 and MQA / MQA-CD on its USB inputs. MQA / MQA-CD is also supported via Toslink optical and coaxial SPDIF. This means you can play high-resolution files and enjoy top-quality music listening sessions.
SMSL RAW PRO-DAC1 : Bluetooth 5.1
The SMSL RAW PRO-DAC1 benefits from an ESS ES9039MSPRO Bluetooth chip, enabling it to support high-definition codecs: aptX and LDAC (24bit/96kHz). This ensures reliable, stable wireless transmission of the audio stream.
SMSL RAW PRO-DAC1: Low-noise power supply
The RAW-DAC1's isolated low-noise power supply provides clean current to all its components.
SMSL RAW PRO-DAC1: I2S input via HDMI
The SMSL's I2S input via HDMI enables it to be powered by an I2S source and, consequently, to deliver a high-resolution signal, unaltered and little affected by jitter.
SMSL RAW PRO-DAC1 overview
| 1 | Display |
| 2 | Indicator light |
| 3 | IR receiver |
| 4 | Multifunction button |
| 5 | Single-ended RCA output |
| 6 | Balanced XLR output |
| 7 | AES/EBU input |
| 8 | Bluetooth antenna |
| 9 | I2S input |
| 10 | SPDIF coaxial input |
| 11 | Toslink optical input |
| 12 | USB-C input |
| 13 | USB-B input |
| 14 | Power input |
SMSL RAW Pro-DAC1 test by Audio Science Review
The RAWPRO-DAC1 provides flawless performance, topping all of my measurements. It is attractive both mechanically and when it comes to the display. As picky as I am, I can't find any faults to report. I am happy to recommend the SMSL RAW Pro-DAC1 stereo DAC.
| Specifications | |
| Product type | DAC |
| DAC chip | ES9039MSPRO |
| USB interface | XMOS XU316 |
| Bluetooth receiver chip | Qualcomm QCC5125 |
| Inputs | 1x USB-C 1x USB-B 1x Coaxial 1x Optical Toslink 1x AES/EBU 1x I2S via HDMI Bluetooth |
| Ouputs | 1x Single-ended RCA output 1x Balanced XLR output |
| Supported sampling rates | USB and I2S: PCM up to 32bit 768kHz, DSD512 USB: DSD DoP256, MQA Optical Toslink, coaxial and AES/EBU: PCM up to 24bit 192kHz, MQA-CD Optical Toslink, coaxial: DSD DoP64 |
| Supported Bluetooth codecs | SBC, AAC, aptX, aptX HD, LDAC |
| Output amplitude | Variable or fixed mode RCA: 2.5Vrms XLR: 5.2Vrms |
| Output impedance | RCA: 100Ω XLR: 100Ω |
| THD+N | RCA: 0.00007% (-123dB) XLR: 0.00005% (-125dB) |
| Dynamic range | RCA: 127dB XLR: 132dB |
| USB transmission | USB 2.0 (Asynchronous) |
| USB compatibility | Windows 7 / 8 / 8.1 / 10 / 11 (driver required) MAC OSX 10.6 et plus Linux |
| General | |
| Power supply | 100-240V AC |
| Power consumption | < 20W |
| Standby power consumption | < 0.5dB |
| Dimensions | 254 x 203 x 48mm |
| Weight | 1.9kg |
| Color | Silver |
| Package | 1x SMSL RAW DAC PRO-DAC1 1x Bluetooth antenna 1x IR remote control (RC-8C) 1x Power cable |
| Condition | New |
| EAN13 | 6970141859925 |
