DENAFRIPS ENYO 15TH Balanced R2R DAC 24bit 1536kHz DSD1024 Black
DAC without volume
Reference 19477
Bon à savoir
The Denafrips Enyo 15TH DAC is an R2R digital-to-analog converter supporting high-resolution audio streams up to PCM 24bit 1536kHz and DSD1024. R2R technology enables Enyo to deliver a natural, faithful and musical sound reproduction.Including €0.05 for ecotax
- Paiement sécurisé
Ce qu'il fait
Denafrips Enyo 15TH Balanced R2R DAC 24bit 1536kHz DSD1024 Black
To obtain a high-performance R2R DAC, Denafrips Enyo 15TH uses a network of ultra-precise resistors. Each resistor is rigorously measured and matched by a machine and validated by human intervention.
Denafrips Enyo 15TH uses a fully symmetrical R2R design. Each channel is decoded by 4 sets of R2R networks. This design features very low linear error, high decoding speed and low digital noise, guaranteeing not only low distortion of the audio signal, but also very low background noise, enabling the listener to fully enjoy his or her music. The DAC also provides the user with NOS or OS and Slow or Sharp filters.
Key features:
- Low-noise power supply
- FPGA-based digital signal processing
- Reclocking and adaptive FIFO buffer
- Supports PCM 1536kHz and DSD1024 streams via USB
- Proprietary USB audio solution via STM32F446 microcontroller
- Proprietary USB interface via STM32F446 microcontroller based on AMR technology
- Pilote USB Thesycon
| Specifications | |
| Product type | Balanced R2R DAC |
| Inputs | 1x Coaxial 1x Optical Toslink 1x USB-B 1x I2S |
| Outputs | 1x Single-ended stereo RCA 1x Balanced stereo XLR |
| Supported sampling rates | USB: PCM up to 1536kHz, DSD up to DSD1024 Optical / Coaxial: PCM up to 24bit 192kHz, DSD up to DSD64 (DoP) |
| Sampling rate modes | Non onversampling (NOS) Oversampling (OS) |
| Output impedances / levels | RCA : 625Ω @ 2Vrms XLR : 1250Ω @ 4Vrms |
| Filters | Slow Sharp |
| Frequency response | 20Hz - 70Hz (-3dB) |
| THD+N | 0.004% |
| SNR | 115dB |
| Dynamic range | > 119dB |
| Crosstalk | -124dB |
| General | |
| Supply voltage | 100-240VAC 50/60Hz (selectable voltage) |
| Consumption | ≤ 20W |
| Color | Black |
| Dimensions | 230 x 215 x 45mm |
| Weight | 3.5kg |
| Package | 1x Denafrips Enyo 15th DAC 1x Power supply cable |
| Condition | New |
| EAN13 | 6978350850030 |
