AUNE N7 Discrete Class A Balanced Headphone Amplifier Preamplifier 6570mW 32 Ohm
Desktop headphone amplifiers
Reference 20998
Bon à savoir
Aune's N7 is a powerful, discreet, fully balanced Class A headphone amplifier-preamplifier. It's based on a combination of JFET transistors for headphone amplification, an independent Class A preamplifier function and R2R volume control for optimal audio signal processing. The use of JFET transistors delivers a warm, smooth sound that will delight tube enthusiasts.
€429.00Tax incl.
Including €0.05 for ecotax
2 years warranty
  • Paiement sécurisé
Ce qu'il fait
Aune N7 Discrete Class A Balanced Headphone Amplifier Preamplifier 6570mW @ 32 Ohm
Aune N7
Aune's N7 is a powerful, discreet, fully balanced Class A headphone amplifier-preamplifier. It's based on a combination of JFET transistors for headphone amplification, an independent Class A preamplifier function and R2R volume control for optimal audio signal processing. The use of JFET transistors delivers a warm, smooth sound that will delight tube enthusiasts. Add to this an attractive 3" color display and a user-friendly interface for a pleasant listening experience and easy device control. In terms of connectivity, the N7 is well equipped with RCA and balanced XLR inputs, two 6.35mm jack and balanced 4.4mm jack headphone outputs, and two preamplified RCA and balanced XLR outputs.
The Aune N7 advantages
Aune N7: JFET transistors for a warm sound
The use of JFET transistors in the N7 offers a sound similar to that of tubes. They provide a soft, warm sound signature, while optimizing signal processing as it enters the device.
Aune N7 JFET transistors
Aune N7 volume control
Aune N7: R2R volume control
The Aune N7 features no less than 2 JRC volume control chips paired with AOPs to form a balanced 4-channel volume control. This offers extremely precise volume control with high stability between left and right channels.
Aune N7: A powerful headphone amplifier
By adjusting the gain, the N7 delivers the output power needed to drive headphones and IEMs with impedances from 16 to 600 Ohms without difficulty. In fact, with a high-gain 32-ohm load, it can deliver up to 6570mW of power.
Aune N7 headphone output power
Load impedance Unbalanced headphone output Balanced headphone output
32 ohm 1900mW 6570mW
300 ohm 213mW 750mW
600 ohm 106mW 370mW
Aune N7 power output
Aune N7: 3" color screen
The N7 boasts a 3" color screen, a user-friendly interface and a remote control for remote control of device functions.
The Aune N7 screen
Aune N7 overview
Overview of Aune N7
1 Single-ended 6.35mm headphone output
2 Balanced 4.4mm headphone output
3 IR receiver
4 Display
5 Multifunction button
6 Balanced XLR input
7 Single-ended RCA input
8 Balanced XLR output
9 Single-ended RCA output
10 18V DC power supply via DC jack / Power on
Product type Headphone amplifier
Preamplifier
Inputs 1x Single-ended RCA input
1x Balanced XLR input
Outputs 1x 6.35mm single-ended headphone output
1x 4.4mm balanced headphone output
1x Single-ended RCA line output
1x Balanced XLR line output
Input/output impedance
RCA input impedance 10kΩ
RCA output impedance 200Ω
XLR input impedance 22kΩ
XLR output impedance 100Ω
Headphone outputs: 6.35mm jack, 4.4mm balanced jack
6.35mm headphone output measures
Frequency response (20Hz-80kHz) ±0.05dB
THD+N < 0.0004% @ 1kHz
SNR > 105dB @ 600Ω
Crosstalk < -100db @ 1khz 600Ω
4.4mm headphone output measures
SNR > 105dB @ 600Ω
Gain-dependent output power
6.35mm headphone output (low gain) 570mW @ 32Ω
190mW @ 100Ω
130mW @ 150Ω
79mW @ 250Ω
66mW @ 300Ω
42mW @ 470Ω
33mW @ 600Ω
Balanced 4.4mm headphone output (low gain) 2150mW @ 32Ω
720mW @ 100Ω
500mW @ 150Ω
316mW @ 250Ω
270mW @ 300Ω
172mW @ 470Ω
135mW @ 600Ω
6.35mm headphone output (high gain) 1900mW @ 32Ω
616mW @ 100Ω
416mW @ 150Ω
252mW @ 250Ω
213mW @ 300Ω
136mW @ 470Ω
106mW @ 600Ω
Balanced 4.4mm headphone output (high gain) 6570mW @ 32Ω
2190mW @ 100Ω
1500mW @ 150Ω
900mW @ 250Ω
750mW @ 300Ω
480mW @ 470Ω
370mW @ 600Ω
Dimensions 208 x 160 x 83mm
Color Black
Package 1x Aune N7 preamplifier headphone amplifier
1x 6.35mm jack to 3.5mm jack adapter
1x AC adapter and power cord
1x Remote control
Condition New
EAN13 6974802511689
Avis
Comments (0)
No customer reviews for the moment.
€429.00AUNE N7 Discrete Class A...
