ROSESELSA RT-5000 DAC Headphone Amplifier ES9038Pro MUSES01 Bluetooth 5.1 32bit 384kHz DSD256 Black
Desktop headphone amplifiers
Reference 20737
Bon à savoir
The RT-5000 from Roseselsa is a DAC and amplifier for headphones using a pair of SABRE ES9038Pro chips and JRC MUSES01 transistors for digital/analogue conversion up to PCM 32bit 384kHz and DSD256 and an output power of 1600mW at 32Ω. These top-of-the-range components ensure quality sound reproduction that's both warm and soft, all housed in a beautiful enclosure.
€599.00Tax incl.
Including €0.05 for ecotax
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
Roseselsa RT-5000 DAC Headphone Amplifier ES9038Pro MUSES01 Bluetooth 5.1 32bit 384kHz DSD256 Black
Roseselsa RT-5000 : Front view
Roseselsa RT-5000 : ESS DAC chip
Roseselsa RT-5000: ES9038Pro DAC chips
The RT-5000 features two ES9038Pro DAC chips using HyperStream II technology to deliver exceptionally accurate, jitter-free conversion. Thanks to ESS's SABRE chips, the RT-5000 is capable of supporting a high-resolution stream of up to 32bit 384kHz PCM and DSD256 while boasting a signal-to-noise ratio (SNR) of 125dB and a harmonic distortion rate (THD) of -112dB.
Roseselsa RT-5000: 10 OPA1612
The RT-5000 also incorporates a total of 10 Texas Instrument OPA1612s. Eight of these are responsible for the I/V circuit and the remaining two act as LPF amplifiers, perfectly complementing the ESS DAC chips to produce HiFi sound reproduction with ultra-low distortion and impressive dynamics.
Roseselsa RT-5000 : OPA1612
Roseselsa RT-5000 : MUSES01 transistors
Roseselsa RT-5000: J-FET JRC MUSES01 transistors
The RT-5000's amplifier stage is based on a pair of J-FET JRC MUSES01 transistors capable of delivering 1600mW of power at 32Ω balanced and 800mW at 32Ω single-ended. This top-of-the-range pair of transistors delivers warm, smooth sound with powerful bass and a wide soundstage.
Roseselsa RT-5000: QCC5125 Bluetooth chip
To provide high-quality Bluetooth connectivity, the RT-5000 is equipped with Qualcomm's QCC5125 chip, which supports the high-definition LDAC, aptX Low Latency and aptX Adaptive protocols.
Roseselsa RT-5000 : Bluetooth chip
Roseselsa RT-5000: Classy aesthetics
Furthermore, in addition to its excellent sound, the RT-5000 is as pleasing to the eye as it is to the ear. Its chassis skilfully combines a CNC-machined aluminium structure with a wooden front panel, leather covering for the upper part and gold plating for the interactive elements, offering a finish that is both classy and elegant.
Aperçu du Roselsa RT-5000
1 6.35mm jack headphone output
2 3.5mm jack headphone output
3 Balanced 4.4mm jack headphone output
4 Gain adjustment
5 Mute
6 EQs preset
7 Operating indicator
8 Volume potentiometer
9 USB-B input
10 Toslink optical input
11 Coaxial input
12 Bluetooth antenna / Pairing
13 RCA line output
14 XLR line output
15 Power on
16 DC power port
Technical specifications
Type of product DAC
Headphone Amplifier
Inputs 1x Coaxial
1x Optical Toslink
1x USB-B
Bluetooth
Outputs 1x Single-ended 3.5mm jack headphone output
1x Balanced 4.4mm jack headphone output
1x Single-ended 6.35mm jack headphone output
1x Single-ended stereo RCA line output
1x Balanced stereo XLR line output
DAC chips 2x ES9038Pro
Amplification chips 2x JRC MUSES01
LPF 2x OPA1612
I/V circuit 8x OPA1612
Bluetooth chip Qualcomm QCC5125
Output power Single-ended: 800mW @ 32Ω
Balanced: 1600mW @ 32Ω
Supported sampling rates PCM up to 32bit 384kHz
DSD up to DSD256
THD -112dB (0.0005%)
SNR 125dB
Channel separation -115dB
Supported Bluetooth codecs LDAC, aptX Adaptive, aptX HD, aptX, AAC, SBC
Supported formats MP3, WMA, FLAC, WAV, AAC, HE-AAC, Apple Lossless, AIFF, DSD, DXD, APE, MQA
Power supply 15V DC 3A
Color Black
Weight 825g
Package 1x Roseselsa RT-5000
1x Mains adapter
1x USB-B to USB-C cable
1x USB-B to USB-A cable
Condition New
Avis
Comments (0)
No customer reviews for the moment.
€599.00ROSESELSA RT-5000 DAC Headphone...
