TOPPING PROFESSIONAL E2X2 Audio Interface USB 2 In 2 Out 24bit 192kHz Black
Digital Interfaces
Jack 6.35mm USB XLRJack 4.4mm Jack 6.35mm192kHzBlackXMOS XU308
Reference 19136
Bon à savoir
With the E2x2, Topping offers an excellent audio interface designed for musicians and audio professionals. This excellent interface offers a very high level of performance for perfectly transparent recording and playback.
€159.00Tax incl.
Including €0.05 for ecotax
2 years warranty
Available now
  • Paiement sécurisé
Ce qu'il fait
Topping E2x2 Audio Interface USB 2 In 2 Out 24bit 192kHz Black
Topping E2x2 : Front view
With the E2x2, Topping offers an excellent audio interface designed for musicians and audio professionals. This great interface offers a very high level of performance for perfectly transparent recording and playback.
Topping E2x2: Key features
Topping E2x2: Microphone preamplifier module
Topping E2x2: Ultra-linear microphone preamplifier module
The Topping E2x2 is equipped with an ultra-linear microphone preamplifier module developed by the brand, with an input noise of just -130.5dBu. Even at its maximum volume level, the E2x2 can maintain a very low noise floor, ensuring that every detail of your recording is perfectly captured. This ultra-linear architecture ensures that the audio signal is transmitted with sufficient precision for a perfectly clear and transparent recording.
Topping E2x2 : Phantom power supply
Equipped with 48V phantom power and a switch to activate or deactivate phantom power, the Topping E2x2 is perfectly compatible with condenser and dynamic microphones.
Topping E2x2 : Use in recording studios
Topping E2x2: Low-noise voltage module
Topping's unique LNRD module provides a stable reference power level for the AD/DA converter chip, unleashing the chip's full potential for high-purity audio transmission.
Topping E2x2 : Mesures de plage dynamique et THD+N
Topping E2x2: High-performance headphone amplifier
With a noise floor of just 0.9uVrms and an output impedance of 1Ω, the Topping E2x2's NFCA-LE headphone amplifier module enables the use of high-sensitivity headphones without distortion and noise.
Topping E2x2: Headphone amplifier and headphone output
The Topping E2x2 offers two gain settings, high gain up to +17dBu and output power of 2x580mW at 32Ω. The combination of this high gain and significant output power means that the Topping E2x2 can easily accompany professional headphones with high impedance, up to 600Ω.
Topping E2x2 : Multiple gain levels
Topping E2x2: zero-latency monitoring
Zero-latency design lets you monitor audio effects in real time during recording or mixing, for enhanced productivity.
Topping E2x2: Analog volume control and wide dynamic range
The volume knobs for the line and headphone outputs use an analog potentiometer, offering excellent precision for easy control of sound level.
Topping E2x2: Independent mixers
Equipped with three 8-channel input mixers, the E2x2 allows easy adjustment and control of audio effects. What's more, its 6 DAW channels and 4 LoopBack channels are designed to adapt to different recording, mixing and playback needs.
Download Topping Professionnal Control Center software
Topping E2x2: independent mixers
Topping E2x2: High audio resolution
The Topping E2x2 adopts an excellent USB XMOS interface, compatible with Windows, Mac, iOS and Android operating systems in particular. It supports high-resolution audio streams for recording and playback, up to PCM 24bit 192kHz.
Topping E2x2 : Interface USB XMOS
Topping E2x2: Two USB-C ports
Topping E2x2 : Dual USB-C ports
The Topping E2x2 uses USB-C connectivity for data transmission and power supply. We recommend connecting the auxiliary power connector if the E2x2 is used in conjunction with a desktop computer, or if 48V phantom power is required, to avoid interference. An external power supply is also recommended when the sound card is used with a smartphone.
Topping E2x2: Aluminum frame
The Topping E2x2's components are protected by a sturdy, durable aluminum-alloy chassis, sober and modern.
Topping E2x2: Connection diagram
Topping E2x2 : Dimensions
Topping E2x2: Dimension diagram
Topping E2x2 : Package
Topping Professional audio interface comparison
E1x2 OTGE2x2E4x4 Pre
OTG interface Yes No No
Power supply USB-C USB-C USB-C
Interface type USB 2.0 USB 2.0 USB 2.0
Monitoring Yes (adjustable mix ratio) Yes (adjustable mix ratio) Yes (adjustable mix ratio)
Input level indicator  1 set of LED 2 set of LED 4 set of LED
Output level indicator 2 set of LED 2 set of LED 4 set of LED
Module preamp micro Ultra-linéaire Ultra-linéaire Ultra-linéaire
Headphone amp NFCA-LE NFCA-LE NFCA-LE
Supported sampling rates USB-C : PCM up to 24bit 192kHz
OTG : PCM up to 24bit 48kHz
PCM up to 24bit 192kHz PCM up to 24bit 192kHz
Software control Yes Yes Yes
Supported OS Mac, Windows, iOS, Android Mac, Windows, iOS, Android Mac, Windows, iOS, Android
Power button Yes Yes Yes
Weight 415g 530g 830g
Mix channels 4 3 4
DAW channels 8 6 8
Loopback channels 6 4 6
Product type Audio interface
USB protocol USB 2.0
Microphon input 2x XLR / 6.35mm jack combo connectors
Instrument inputs 2x XLR / 6.35mm jack combo connectors
Line outputs 2x Jack 6.35mm
Headphone output 1x Jack 6.35mm
Direct zero-latency monitoring Yes (with mix button)
Input Vumeter Yes (2x8 LED indicators)
Output Vumeter Yes (2x8 LED indicators)
Microphone preamp modules Ultra-linear
Headphone amplifier modules NFCA-LE
Supported sampling rates PCM up to 24bit 192kHz
Software control Yes (Topping Professional Control)
DAW channels 6x
MICROPHONE INPUT MEASUREMENTS (@ 24bit 96kHz)
Equivalent input noise -130.5dBu @ A-wt, 150Ω
THD+N -110dB (0.0003%) @ A-wt
Dynamic range 115dB @ A-wt
SNR 115dB
Crosstalk -140dB @ 1kHz
Frequency response 20Hz - 40kHz (±0.2dB)
Max input level 8.6dBu
Input impedance 1.5kΩ
Available gain 58dB + 20dB (20db digital gain)
Phantom power 48V
XLR connector
LINE INPUT MEASUREMENTS (@ 24bit 96kHz)
THD+N -107dB (0.00045%) @ A-wt
SNR 115dB
Frequency response 20Hz - 40kHz (±0.1dB)
Max input level 23.9dBu
Input impedance 6kΩ
Connectors Jack 6.35mm TRS
Instrument inputs measurements (@ 24bit 96kHz)
THD+N -108dB (0.0004%) @ A-wt
SNR 115dB
Frequency response 20Hz - 40kHz (±0.3dB)
Max input level 14.8dBu
Input impedance 1MΩ
Connectors Jack 6.35mm TS
Line outputs measurements (@ 24bit 96kHz)
THD+N -100dB (0.001%) @ A-wt
Analog dynamic range 127dB @ A-wt, -40dB attenuation
SNR 115dB @ A-wt
Crosstalk -128dB @ 1kHz
Max output level 14dBu
Noise 1.8uVrms @ A-wt
Output impedance 100Ω
Connectors Balanced Jack 6.35mm TRS
Headphone output measurements (@ 24bit 96kHz)
Analog dynamic range 132dB @ A-wt, -40dB attenuation
SNR 115dB @ A-wt
Crosstalk -120dB @ 1kHz
Max output level 0dBu @ Gain = L
17dBu @ Gain = H
Noise 1uVrms @ A-wt
Output impedance 1Ω
Connector Jack 6.35mm TRS stereo
Headphone output power 2x580W @ 32Ω, THD+N < 1%
2x380W @ 64Ω, THD+N < 1%
2x198W @ 150Ω, THD+N < 1%
2x105W @ 300Ω, THD+N < 1%
2x55W @ 600Ω, THD+N < 1%
Power supply 5VDC 0.8A via USB-C
Dimensions 18.7 x 12.9 x 5cm
Weight 530g
Color Black
Condition New
Input Jack 6.35mm
USB
XLR
Output Jack 4.4mm
Jack 6.35mm
Max sampling rate 192kHz
Color Black
Interface chip XMOS XU308
EAN13 6977577360858
Avis
Comments (2)
Grade 4.5/5
No customer reviews for the moment.
€159.00TOPPING PROFESSIONAL E2X2 Audio...
