TOPPING PROFESSIONAL E2X2 OTG USB Audio Interface 2 Inputs 2 Outputs 24bit 192kHz White
Digital Interfaces
Reference 19306
Bon à savoir
Topping's E2x2 OTG is an excellent audio interface designed for musicians and audio professionals. This excellent interface offers a very high level of performance for perfectly transparent recording and playback.
€199.00Tax incl.
Including €0.05 for ecotax
2 years warranty
Available now
  • Paiement sécurisé
Ce qu'il fait
TOPPING PROFESSIONAL E2X2 OTG : 3/4 view
TOPPING PROFESSIONAL E2X2 OTG: Key features
TOPPING PROFESSIONAL E2X2 OTG : Pre-amplifier module
Topping E2x2 OTG : Ultra-linear microphone preamplifier module
The Topping E2x2 OTG is equipped with an ultra-linear microphone preamplifier module developed by the brand, with an input noise of just -130.5dBu. Even at its maximum volume level, the E2x2 OTG can maintain a very low noise floor, ensuring that every detail of your recording is perfectly captured. This ultra-linear architecture ensures that the audio signal is transmitted with sufficient precision for a perfectly clear and transparent recording.
Topping E2x2 OTG : Phantom power supply
Equipped with 48V phantom power and a switch for activating or deactivating phantom power, the Topping E2x2 OTG is perfectly compatible with condenser and dynamic microphones.
TOPPING PROFESSIONAL E2X2 OTG: example of use
TOPPING PROFESSIONAL E2X2 OTG: power supply unit
Topping E2x2 OTG : Low-noise voltage module
Topping's unique LNRD module provides a stable reference power level for the AD/DA converter chip, unlocking the chip's full potential for high-purity audio transmission.
Topping E2x2 OTG : High-performance headphone amplifier
With a noise floor of just 0.9uVrms and an output impedance of 1Ω, the Topping E2x2 OTG's NFCA-LE headphone amplifier module allows high-sensitivity headphones to be used without distortion and noise. The Topping E2x2 OTG offers two gain settings, a high gain of up to +17dBu and an output power of 2x580mW into 32Ω. The combination of this high gain and significant output power means that the Topping E2x2 OTG can easily accompany professional headphones with a high impedance, up to 600Ω.
TOPPING PROFESSIONAL E2X2 OTG: headphone output
Topping E2x2 OTG : Zero-latency monitoring
The zero-latency design allows audio effects to be monitored in real time during recording or mixing, for improved productivity.
Topping E2x2 OTG : Analogue volume control and wide dynamic range
The volume knobs for the line output and headphone output use an analogue potentiometer, offering excellent precision for easy control of sound level.
TOPPING PROFESSIONAL E2X2 OTG: volume control
Topping E2x2 OTG : Independent mixers
Equipped with four 12-channel input mixers, the E2x2 OTG allows easy adjustment and control of audio effects. Furthermore, its 8 DAW channels and 6 LoopBack channels are designed to adapt to different recording, mixing and playback needs.
DOWNLOAD TOPPING PROFESSIONNAL CONTROL CENTER SOFTWARE
TOPPING PROFESSIONAL E2X2 OTG: control software
TOPPING PROFESSIONAL E2X2 OTG: Xmos chip
Topping E2x2 OTG : High audio resolution
The Topping E2x2 OTG adopts an excellent USB XMOS interface, compatible with Windows, Mac, iOS and Android operating systems in particular. This supports high-resolution audio streams for recording and playback, up to PCM 24bit 192kHz.
Topping E2x2 OTG : Triple USB-C ports
The Topping E2x2 OTG uses two USB-C connectors for data transmission, including an OTG port, and one connector for power. All you need is a USB OTG cable to connect directly to your mobile phone for live streaming, providing lossless sound transmission quality. It is recommended that the auxiliary power connector is connected if the E2x2 OTG is used in conjunction with a desktop computer or if 48V phantom power is required, to avoid interference. An external power supply is also recommended when the sound card is used with a smartphone.
Topping E2x2 OTG : Connectors
TOPPING PROFESSIONAL E2X2 OTG : Numbered diagram
1 Mic/Instr/Line input
2 Mic/Instr/Line input
3 Headphone output 6.35mm Jack
4 Anti-theft lock
5 Power supply
6 USB-C input
7 USB-C OTG input
8 Optical Jack output
9 Auxiliary output 3.5 mm Jack
10 6.35 mm Jack line outputs
Topping Professional audio interface comparison
E1x2 OTGE2x2 OTGE2x2E4x4 Pre
OTG interface Yes Yes No No
Power supply USB-C USB-C USB-C USB-C
Interface type USB 2.0 USB 2.0 USB 2.0 USB 2.0
Monitoring Yes (adjustable mix ratio) Yes (adjustable mix ratio) Yes (adjustable mix ratio) Yes (adjustable mix ratio)
Input level indicator 1 set of LED 2 set of LED 2 set of LED 4 set of LED
Output level indicator 2 set of LED 2 set of LED 2 set of LED 4 set of LED
Module preamp micro Ultra-linear Ultra-linear Ultra-linear Ultra-linear
Headphone amp NFCA-LE NFCA-LE NFCA-LE NFCA-LE
Supported sampling rates USB-C : PCM up to 24bit 192kHz
OTG : PCM up to 24bit 48kHz
SPDIF : PCM up to 24bit 192kHz
PCM up to 24bit 192kHz PCM up to 24bit 192kHz
Software control Yes Yes Yes Yes
Supported OS Mac, Windows, iOS, Android Mac, Windows, iOS, Android Mac, Windows, iOS, Android Mac, Windows, iOS, Android
Power button Yes Yes Yes Yes
Weight 415g 530g 530g 830g
Mix channels 4 4 3 4
DAW channels 8 8 6 8
Loopback channels 6 6 4 6
Product type Audio interface
USB protocol USB 2.0
Microphone input 2x XLR / 6.35mm jack combo connectors
Entrées instruments 2x XLR / 6.35mm jack combo connectors
Line outputs 2x Jack 6.35mm
Headphone output 1x Jack 6.35mm
Auxiliary output 1x Jack 3.5mm
OTG output 1x USB-C
SPDIF output 1x Optical Jack
Direct zero-latency monitoring Yes (with mix button)
Input Vumeter Yes (2x8 LED indicators)
Output Vumeter Yes (2x8 LED indicators)
Microphone preamp modules Ultra-linear
Headphone amplifier modules NFCA-LE
Supported sampling rates PCM up to 24bit 192kHz
Software control Yes (Topping Professional Control)
DAW channels 8x
MICROPHONE INPUT MEASUREMENTS (@ 24BIT 96KHZ)
Equivalent input noise -130.5dBu @ A-wt, 150Ω
THD+N -110dB (0.0003%) @ A-wt
Dynamic range 115dB @ A-wt
SNR 115dB
Crosstalk -140dB @ 1kHz
Frequency response 20Hz - 40kHz (±0.2dB)
Max input level 8.6dBu
Input impedance 1.5kΩ
Available gain 58dB + 20dB (20db digital gain)
Phantom power 48V
XLR connector
LINE INPUT MEASUREMENTS (@ 24bit 96kHz)
THD+N -107dB (0.00045%) @ A-wt
SNR 115dB
Frequency response 20Hz - 40kHz (±0.1dB)
Max input level 23.9dBu
Input impedance 9kΩ
Connectors Jack 6.35mm TRS
INSTRUMENT INPUTS MEASUREMENTS (@ 24bit 96kHz)
THD+N -108dB (0.0004%) @ A-wt
SNR 115dB
Frequency response 20Hz - 40kHz (±0.3dB)
Max input level 14.8dBu
Input impedance 1MΩ
Connectors Connecteur Jack 6.35mm TS
LINE OUTPUTS MEASUREMENTS (@ 24bit 96kHz)
THD+N -100dB (0.001%) @ A-wt
Analog dynamic range 127dB @ A-wt, -40dB attenuation
SNR 115dB @ A-wt
Crosstalk -128dB @ 1kHz
Max output level 14dBu
Noise 1.8uVrms @ A-wt
Output impedance 100Ω
Connectors Balanced Jack 6.35mm TRS
Auxiliary output measurements
Analog dynamic range 122dB @ A-wt, -40dB atténuation
SNR 115dB @ A-wt
Crosstalk -108dB @ 1kHz
Maximum output level 8dBu
Noise 1.5uVrms @ A-wt
Output impedance 50Ω
Connector Balanced Jack 3.5mm TRS
HEADPHONE OUTPUT MEASUREMENTS (@ 24bit 96kHz)
Analog dynamic range 132dB @ A-wt, -40dB atténuation
SNR 115dB @ A-wt
Crosstalk -120dB @ 1kHz
Max output level 0dBu @ Gain = L
17dBu @ Gain = H
Noise 1uVrms @ A-wt
Output impedance 1Ω
Connector Jack 6.35mm TRS stereo
Headphone output power 2x580W @ 32Ω, THD+N < 1%
2x380W @ 64Ω, THD+N < 1%
2x198W @ 150Ω, THD+N < 1%
2x105W @ 300Ω, THD+N < 1%
2x55W @ 600Ω, THD+N < 1%
OTG output measurements (@ 24bit 192kHz)
THD+N -130dB (0.00003%) @ A-wt
Dynamic range 138dB @ A-wt
SNR 138dB @ A-wt
Crosstalk -154dB @ 1kHz
Frequency response 20Hz - 20kHz (±0.1dB)
Max output level -0.5dBFS
Connector USB-C OTG
SPDIF output measurements (@ 24bit 192kHz)
THD+N -144dB (0.000006%) @ A-wt
Dynamic range 144dB @ A-wt
SNR 144dB @ A-wt
Crosstalk -160dB @ 1kHz
Max output level 0dBFS
Connector Optical Jack
Power supply 5VDC 0.8A via USB-C
Dimensions 18.7 x 12.9 x 5cm
Weight 530g
Color White
Package 1x E2X2 OTG Silver
1x USB-A to USB-C Cable
1x USB-C to USB-C Cable
1x 6.35mm to 3.5mm Jack Adapter
Condition New
EAN13 6977577360988
Avis
Comments (0)
No customer reviews for the moment.
€199.00TOPPING PROFESSIONAL E2X2 OTG...
