DSPEAKER ANTI-MODE X2 Room Correction and Equalizer DSP
DSP & A/V Processors
Optical RCA SPDIF USBRCANCBlack
Reference 16990
Bon à savoir
Compact yet extremely powerful, the DSPeaker Anti-Mode X2 presents itself as a DSP to perform acoustic room correction and equalization tasks with great efficiency. It features the brand new Anti-Mode™ 3 algorithm, capable of automatically optimizing your main speakers and an optional subwoofer to your acoustic environment. This makes it simple and quick to improve the sound quality of an existing HiFi system.
€625.00Tax incl.
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
DSPeaker Anti-Mode X2 DSP Correction Acoustique et Égaliseur
A fully customizable tone control feature is also available, in addition to an advanced digital crossover and subsonic filter. Most features are adjustable in real time using the included remote control. Several sound profiles are also available, allowing quick access to previously saved settings.
An efficient room correction
In order to limit or even cancel the impact of the multiple defects that a listening room can present on the quality of reproduction of an audio system, the DSPeaker Anti-Mode X2 proposes a powerful acoustic room correction system. It uses a microphone calibration system to solve problems such as reverberation, echo, sound reflection, and speaker/subwoofer mismatch, in order to allow your audio system to really shine. This correction is fully automatic and transparent.
Tone control
In addition to its acoustic correction function, the DSPeaker Anti-Mode X2 provides a tone control that allows you to manually adjust the bass, midrange and treble levels. These settings can be saved in three sound profiles that can be accessed at any time.
Easy integration
The DSPeaker Anti-Mode X2 is placed directly between your sources and your amplifier, preamplifier or active speakers. It offers an adapted connectic, composed of a combined RCA stereo/coaxial input, an optical Toslink input and a USB-C port. The digital section supports, thanks to its integrated DAC, audio streams up to PCM 24bit 192kHz.
Concerning the outputs, we find stereo RCA and a subwoofer output. The RCA output offers the possibility of being configured on a variable level for a direct connection with a power amplifier.
1 Microphone input
2 Display
3 IR receiver
4 12VDC power input
5 USB-A input (for firmware update)
6 USB-C audio input
7 Subwoofer output
8 Right channel RCA output
9 Left channel RCA output
10 Right channel RCA input
11 Left channel RCA input / Coaxial input
12 Optical input
Product type Room correction DsP
Inputs 1x Stereo RCA / SPDIF Coaxial ccombo
1x Optical Toslink
1x USB-C
1x Microphone input
Outputs 1x Stereo RCA
1x Subwoofer (RCA)
Supported sampling rates USB : PCM up to 24bit 96kHz
SPDIF : PCM up to 24bit 192kHz
Frequency range (analog to analog) 5Hz-22kHz
Analog input level 2.3Vrms (max)
Analog input SNR 100dB
Analog input THD (-6dB) < 0.002%
Line output level 2.2Vrms (max)
Line output SNR 107dB
Line output THD (-6dB) < 0.0015%
Subwoofer output level 2.3Vrms (max)
Subwoofer output SNR 100dB
Subwoofer output THD (-6dB) < 0.03%
Supply voltage 12VDC
Consumption 1.5W
Standby consumption 0.1W
Dimensions (L*P*H) 126*80*28mm
Weight 300g
Color Black
Package 1* DSPeaker Anti-Mode X2
1* Measuring microphone
1* Remote control
1* Power supply
Condition New
Input Optical
RCA
SPDIF
USB
Output RCA
Max sampling rate NC
Color Black
EAN13 6430044030307
Avis
Comments (0)
No customer reviews for the moment.
€625.00DSPEAKER ANTI-MODE X2 Room...
