MINIDSP DDRC-24 Interface DAC DSP Processor SHARC ADSP21489 Dirac Live
DSP & A/V Processors
Optical RCARCA48kHzBlack
Reference 14310
Bon à savoir
The MiniDSP DDRC-24 is the most compact Dirac Live and DAC processor in the range, allowing you to enjoy the excellent acoustic correction solution without the hassle of a large device.
€469.00Tax incl.
Including €0.05 for ecotax
2 years warranty
Available now
  • Paiement sécurisé
Ce qu'il fait
MiniDSP DDRC-24
MiniDSP DDRC-24 Interface DAC Processeur DSP SHARC ADSP21489 Dirac Live
Powered by a 400MHz Analog Devices SHARC processor, the DDRC-24 features 4 channels of outputs, allowing for example the integration of a subwoofer or stereo system associated with the Dirac Live system. Dirac Live allows access to numerous parameters such as a mixing matrix or crossover filters via an easy to use interface. Inputs include stereo RCA, Toslink Optical, and Mini USB (XMOS), both of which are connected to a DAC that supports PCM sample rates up to 192kHz.
The DDRC-24 comes with a Dirac Live license and can also be used with the Room EQ Wizard software to perform measurements prior to the Dirac calibration if required.
MiniDSP DDRC-24 Interface DAC Processeur DSP SHARC ADSP21489 Dirac Live MiniDSP DDRC-24 Interface DAC Processeur DSP SHARC ADSP21489 Dirac Live MiniDSP DDRC-24 Interface DAC Processeur DSP SHARC ADSP21489 Dirac Live
The UMIK-1 microphone is not supplied with this product. It can be purchased separately (see accessories) to perform acoustic measurements using the Dirac Live software.
Product type DSP
DSP Chip Analog Devices SHARC ADSP21489 32bit floating point 400Mhz
Internal processing resolution and sample rate 32bit / 48kHz
DAC resolution 24bit
Inputs 1x Unbalanced stereo RCA
1x Optical Toslink
1x Mini USB (ASRC : 20Hz - 216kHz)
Outputs 2x Unbalanced stereo RCA
USB Interface XMOS Xcore200
Input levels 2Vrms / 4Vrms (switchable)
Output level 2Vrms
Input impedance 10kΩ
Output impedance 560kΩ
Calibration software Plugin DDRC-24
Filtering technology Dirac Live
DSP presets Up to 4 presets
Impulse response correction
Infrared remote learning
Compatibility Windows
Mac
Bass management
Room EQ Wizard support
Dimensions 119 x 107 x 27mm
Power supply 12VDC 2.5mm via Jack DC 2.1mm
Case material Aluminium
Color Black
Package 1x MiniDSP DDRC-24
1x Dirac Live license
1x Power supply 12V
1x USB cable
1x Plugin for DSP control
Condition New
Input Optical
RCA
Output RCA
Max sampling rate 48kHz
Color Black
EAN13 0691046947376
Avis
Comments (0)
No customer reviews for the moment.
€469.00MINIDSP DDRC-24 Interface DAC...
