MINIDSP FLEX Audio Processor DSP SHARC ADSP21489 XMOS Bluetooth
DSP & A/V Processors
Bluetooth Optical RCA...RCA96kHzBlack
Reference 15884
Bon à savoir
The miniDSP Flex is the brand's 3rd generation 2-in/4-out audio processor. It keeps the powerful floating point processor used previously with a redesigned input/output architecture to offer versatile connectivity. This version features single-ended RCA stereo inputs and outputs, as well as a full digital input panel with Bluetooth, USB-B, coaxial and Toslink optical.
€629.00Tax incl.
Including €0.05 for ecotax
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
miniDSP Flex
miniDSP Flex Processeur Audio DSP Dirac Live SHARC ADSP21489 XMOS Bluetooth
An OLED display on the front panel and a volume controller make it easy to control the unit. Of course, the Flex series incorporates the powerful audio processing features developed by miniDSP: a flexible parametric equalizer, IIR and FIR filters, crossovers, the possibility to program the biquad filter and delay for each output... In addition, all systems can be software enhanced with the Dirac Live® correction solution for fine tuning over the entire frequency range.
The miniDSP Flex offers a wide range of uses and applications, whether in combination with a compact digital stereo preamplifier, for integration with a subwoofer or for active speaker optimization.
The DIRAC licence is not included, but available here.
Test du MiniDSP Flex par Audio Science Review (Amir)
What a nice combination of functionality, usability and performance! As with many DAC companies, it is clearly Minidsp has put strong focus on chasing away sources of noise and distortion. All AV processor and receiver companies lose any excuses they have for not providing this level of performance seeing how the Flex also implements various signal processing modules. "
Product type DSP
CPU Analog Devices floating point DSP SHARC ADSP21489 400MHZ
USB Interface XMOS
Inputs Bluetooth
1x USB-B
1x Coaxial
1x Optical Toslink
1x Stereo RCA
Outputs 2x Stereo RCA
Supported Bluetooth codecs AAC, SBC, aptX, aptX HD, LDAC
Recording feature via USB 4 channel output processing
Processing sampling rate 32bit 96kHz
(32bit 48kHz with Dirac Live® license)
Analog input impedance 100kΩ
Analog output impedance 200Ω
Max input/output levels 2Vrms / 2Vrms
Frequency response 20Hz-20kHz ±0.1dB
SNR (digital to analog) 120dB(A)
THD+N (digital to analog) -110dB (0.0003%) ±3dB
Crosstalk (digital to analog) -120dB
SNR (aanlog to analog) 115dB(A)
THD+N (analog to analog) -106dB (0.0005%) +/-3dB
Crosstalk (analog to analog) -115dB
Filterinf technology FIR + IIR
Dirac Live® optional: 3x full range correction (20~20kHz)
DSP presets up to 4 profiles
Supply voltage 12VDC 1.6A (power adapter included)
Consumption 9W
Standby consumption 2.5W
Dimensions 150 x 180 x 41mm
Color Black
Package 1x miniDSP Flex
1x Remote control
1x Power adapter
Condition New
Input Bluetooth
Optical
RCA
SPDIF
USB
Output RCA
Max sampling rate 96kHz
Color Black
EAN13 8785256845415
Avis
Comments (4)
Grade 5/5
No customer reviews for the moment.
€629.00MINIDSP FLEX Audio Processor...
