Including €0.30 for ecotax
Available now
- Paiement sécurisé
Ce qu'il fait
Source selector ALPS SRRN 820c 3 positions 1 channel B>
For example, they can be mounted in a preamplifier to select the sources.
- Maximum Power: 0.15A 12V DC
- Lifetime: 10000 cycles Li>
- Made in Japan Li>
- Length of the axis: 18 mm (flat 12mm) Li>
Operating temperature range | -10 ° to + 60 ° | ||
Rating (max.) / (Min.) (Resistive load) | 0.15A 12V DC / 50μA 3V DC Font> | ||
Electrical Performance | Contact resistance (Initial performance / After lifetime) | 50mΩ max. / 100mΩ max. | |
Insulation resistance | 100MΩ min. 500V DC Font> | ||
Voltage proof | 500V AC for 1 minute | ||
Mechanical performance | Terminal strength | 5N for 1 minute | |
Actuator strength | Rotational direction | 1N · m Font> | |
Push direction | 100N | ||
Wobble of actuator (load at the tip of shaft: 5N) | Measuring position from surface mounting | 15mm | |
Shaft wobble (max. Value) | 0.25mm max. | ||
Applicable mounting dimension | 20mm | ||
Resistance to soldering heat | Manual soldering | 350 ± 10 °, 3 (+1.0) s | |
Dip soldering | 260 ± 5 °, 10 ± 1 s | ||
durability | Operating life without load | 10,000 cycles 70mΩ max. Font> | |
Operating life with load (Load: as ratings) | 10,000 cycles 100mΩ max. Font> | ||
Environmental Performance | Cold | -20 ± 2 ° for 96h | |
Dry heat | 85 ± 2 ° for 96h | ||
Damp heat | 40 ± 2 °, 90 to 95% RH for 96h | ||
P>
P>
| Condition | New |
