DD M130B USB-C to MMCX Copper OCC Cable Portable Headphone Amplifier DAC ES9603Q 1.2m
Headphones Cables
Reference 19679
Bon à savoir
The M130B cable from ddHiFi is an all-in-one headphone cable, which as well as offering signal transmission via an OCC copper core, includes an ES9603Q chip that acts as a DAC and headphone amplifier. Not only does this cable offer digital/analogue conversion at a sampling rate of up to PCM 384kHz, it also boasts an output power of 45mW+45mW at 32Ω.Including €0.05 for ecotax
Last items in stock!
- Paiement sécurisé
Ce qu'il fait
ddHiFi M130B : OCC copper core
To ensure optimum data transmission, the ddHiFi M130B cable uses a conductor made up of 49 strands of 0.06mm OCC copper coupled with a shield made of 112 strands of 0.05mm OFC copper.
ddHiFi M130B : ES9603Q chip
The M130B cable is equipped with an ESS ES9603Q chip, enabling it to convert files up to PCM 384kHz, allowing you to enjoy tracks in lossless format, generally offered by streaming platforms at a maximum of 192kHz. Furthermore, thanks to the ES9603Q chip, the M130B cable offers an output power of 45mW+45mW at 32Ω, so it can drive the majority of earphones on the market.
ddHiFi M130B : MEMS microphone
Nestled inside the splitter is a high-performance MEMS microphone that can be used for everyday phone calls and other tasks. The central button on the splitter can be used to control your phone calls or music playback.
| Specifications | |
| Product type | Headphone cable Portable DAC Mobile headphone amplifier |
| Connectors | 1x USB-C 2x CIEM 0.78mm |
| Length | 1.2m |
| Conductive material | OCC Copper |
| Shielding material | OFC Copper |
| DAC chip | ES9603Q |
| Supported sampling rates | PCM up to 384kHz |
| Dynamic range | >120dB |
| Total harmonic distortion more noise (THD+N) | <0.008% @32Ω |
| Signal-to-noise ratio (SNR) | ≥112dB |
| Frequency response | 20Hz - 20kHz |
| Noise level | <3µV |
| Output power | 45mW+45mW @32Ω |
| Crosstalk | <-60db 32="" td=""> |
| General | |
| Color | Copper |
| Poids | 26g |
| Package | 1x ddHiFi M130B |
| Condition | New |
| EAN13 | 6972062152406 |
