DOUK AUDIO VU56PRO RGB LED VU Meter Mic+Line
Hifi Devices
Reference 21120
Bon à savoir
The DOUK Audio VU56PRO is an RGB LED VU meter with 8 display effects, operating effectively on the 20Hz-20KHz frequency band. The signal input is via stereo RCA or 3.5mm Aux jack, but it is also possible to use the VU56PRO's built-in microphone so that the signal does not pass through the device.
€99.00Tax incl.
Including €0.05 for ecotax
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
DOUK AUDIO VU56PRO
The DOUK Audio VU56PRO is an RGB LED VU meter with 8 display effects, operating effectively on the 20Hz-20KHz frequency band. The signal input is via stereo RCA or 3.5mm Aux jack, but it is also possible to use the VU56PRO's built-in microphone so that the signal does not pass through the device. However, if you decide to pass the signal through it, it has an RCA or 3.5mm Aux jack output. The VU56PRO is powered by 5V 1A via micro-USB and comes with a remote control for remote operation.
DOUK Audio VU56PRO overview
1 RCA output
2 RCA input
3 3.5mm Aux jack output
4 3.5mm AUX Jack Input
5 Power / Display Effect Selector
6 Line / Microphone input selection
7 Built-in microphone
8 5V micro USB power supply
Product type Vumeter
Inputs 1x Stereo RCA
1x 3.5mm Aux Jack
Outputs 1x Stereo RCA
1x 3.5mm Aux Jack
Max input level 2.5Vrms
Max. effective input level 1.8 Vrms (the VU56 PRO will always display full power when this value is exceeded)
Monitoring frequency range 20Hz-20kHz
Input impedance 10KΩ
Brightness adjustment 4 level
Display color Green or red
Display effects 8 effects
Display length gain 3 levels adjustable (-3 dB, 0 dB, +3 dB)
Display mode PPM mode (peak programme meter) / VU Mode (volume unit)
Holding time of peak LED Adjustable
Drop speed of main bar/peak LED Adjustable
Remote control
Power suply DC 5V (≥1A) via micro USB
Dimensions 154 x 116 x 47mm
Weight 400g
Color Black
Package 1x DOUK Audio VU56PRO VU meter
1x 3.5mm AUX jack cable
1x Remote control (requires CR2025 battery, not included)
1x USB-A to Micro USB power cable (AC adapter not included)
Condition New
Avis
Comments (0)
No customer reviews for the moment.
€99.00DOUK AUDIO VU56PRO RGB LED VU...
