SOFTEARS STUDIO4 In-Ear Monitors IEM Balanced Armature 12 Ohm 123dB 5Hz-40kHz
In-Ear Earphones
Reference 20724
Bon à savoir
With the Studio4, Softears presents in-ear monitors specially developed for professional use. Relying on 4 Balanced Armature drivers, these earphones offer the most neutral sound possible, making them ideal for monitoring or in a recording studio.Including €0.05 for ecotax
- Paiement sécurisé
Ce qu'il fait
Softears Studio4 In-Ear Monitors IEM Balanced Armature 12 Ohm 123dB 5Hz-40kHz
Softears Studio4: Professional earphones
The Studio4s have been designed primarily for professional use, using 4 balanced armature drivers to deliver the most neutral and flat sound reproduction possible, perfect for monitoring or use in recording studios. Furthermore, the Studio4s feature excellent acoustic isolation, effectively reducing external interference, making them ideal for outdoor use.
Softears Studio4: Wearing comfort
The body of the Studio4 is made from 3D-printed medical-grade resin, which not only contributes to ultra-precise sound reproduction but also offers maximum wearing comfort. Compared with other Studio models, the Studio4s have a smaller external diameter and a reduced nozzle, making them both more comfortable and compatible with a wider range of eartips.
Softears Studio4: Extended compatibility
The frequency division architecture has been specially designed to match the output characteristics of professional audio interfaces as closely as possible. The result is earphones that are very easy to drive and have an almost straight impedance curve, enabling them to deliver very consistent performance, whatever the source in use.
Softears Studio4: High-quality cable
The Studio4 is supplied with a CIEM to 3.5mm jack cable made from OFC copper, guaranteeing high-quality signal transmission so you can get the most out of your earphones. Furthermore, an OFC copper extension cable is also included.
| Specifications | |
| Product type | In-ear monitors |
| Drivers | 4x Balanced armature drivers |
| Impedance | 12Ω @ 1kHz |
| Sensitivity | 123dB/Vrms @ 1kHz |
| Total harmonic distortion (THD) | < 1% @ 1kHz |
| Frequency response | 5Hz-40kHz |
| Earphone connectors | CIEM 0.78mm 2 Pins |
| Cable termination | Jack 3.5mm |
| Cable conductor material | OFC copper |
| General | |
| Color | Black |
| Package | 1x Softears Studio4 1x Jack 3.5mm to CIEM cable 1x Jack 3.5 male to Jack 3.5mm female extension cable 1x Carrying bag 3x Pairs of ear tips |
| Condition | New |
| EAN13 | 6974348920280 |
