Interface USB-B to I2S / DSD / SPDIF / MQA XMOS XU316 32bit 768kHz DSD512
Interface Modules
Reference 19690
Bon à savoir
This USB to I2S, DSD, SPDIF and MQA interface is equipped with an XMOS XU316 USB chip and is designed for high-fidelity audio applications. The interface supports digital streams with a sampling frequency of up to 32bit 768kHz PCM, DSD512 on its I2S output and up to 192kHz PCM on the SPDIF output. Furthermore, it should be noted that MQA is supported here, thanks in particular to the presence of the XMOS XU316 chip.
€75.90Tax incl.
Including €0.05 for ecotax
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
Interface USB-B XMOS XU316 : Front view
Type of product Digital interface
Input USB-B
Outputs I2S
SPDIF
Supported sampling rates I2S : PCM up to 32bit 768kHz / Native DSD up to DSD512
SPDIF : PCM up to 24bit 192kHz
Interface chip XMOS XU316
Compatibility Windows 7 / 8 / 8.1 / 10 / 11 (Driver required)
Mac OS X10.6+
Linux
Android
iOS
Spacing holes 22mm x 60mm
Clock jitter 75pS
MQA support Yes
Dimensions 35mm x 69mm (excluding connector)
Weight 20g
Package 1x Digital interface
1x Pin header 2x10 Pins 2.54mm
Condition New
Avis
Comments (0)
No customer reviews for the moment.
€75.90Interface USB-B to I2S / DSD /...
