YORK PICO C Digital Interface USB-C to I2S 192kHz
Interface Modules
Reference 21087
Bon à savoir
The York Pico C is a USB audio interface designed to offer great flexibility of use beyond conventional USB to I2S applications. It combines a UAC2 interface for audio input and output with a HID interface for user control, such as I2C operations and GPIO control.
€57.00Tax incl.
Including €0.05 for ecotax
2 years warranty
Available now
  • Paiement sécurisé
Ce qu'il fait
York Pico C USB-C Digital Interface USB-C to I2S 192kHz
York Pico C : Vue de haut
Key features:
  • Flexible configuration: device settings and firmware updates can be managed using a dedicated PC utility.
  • HID Interface: Service information and device configuration
  • Optional Serial Interface (virtual COM port)
  • Multiple Audio Output Options: Supports I2S, S/PDIF, TDM and interfaces for NOS DACs (e.g., AD1862, PCM63, TDA1541 etc).
  • Various Clocking Options: Includes module oscillators, external clock (slave mode), and internal PLL clocking.
  • I2C Integration with DSP: Allows simultaneous audio input/output and DSP programming, like ADAU1452/67
  • No drivers required for Windows 10/11, Linux, MacOS, Android, iOS.
  • Bootloader: Enables easy and fail safe firmware update.
York Pico C: Audio capacity
This digital audio module supports up to eight input and output channels, with sampling frequencies up to 192kHz, extendable to 384kHz via an external clock. It is based on a PIC32MZ microcontroller with MIPS architecture, integrating a high-speed USB interface and a DSP instruction set enabling the implementation of embedded audio processing. The internal clock is provided by two low-noise oscillators of 22.5792MHz and 24.576MHz, dedicated to sampling rates of 44.1 and 48kHz, powered by an isolated LDO regulator. An external clock input is also available, compatible with ratios of 256/512/1024fs.
York Pico C : dimensions
Type of product Digital interface
Input USB-C
Output Soldering pads I2S
Sampling rate 192kHz
384kHz with external clock
Output format I2S
TDM
PCM
Clocks 22.5792MHz clock
24.576MHz clock
OS No drivers required for Windows 10/11, Linux, MacOS, Android, and iOS
Dimensions 68.58 x 31.75mm
Hole spacing 63.5 x 25mm
Package Sold by unit
Condition New
Avis
Comments (0)
No customer reviews for the moment.
€57.00YORK PICO C Digital Interface...
