TECTONIC TEBM65C20F-4 Full Range BMR Speaker 30W 4 Ohm 81dB 60Hz-20kHz Ø7.62cm
Midrange / Midbass / Full Range
Reference 20751
Bon à savoir
Tectonic's BMR range consists of full-range speakers designed to cover a very wide part of the audible spectrum. For example, the TEBM65C20F-4 features an extended frequency response from 60Hz to 20kHz, as well as wide directivity.
€29.00Tax incl.
Including €0.05 for ecotax
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
Tectonic TEBM65C20F-4 Full Range BMR Speaker 30W 4 Ohm 81dB 60Hz-20kHz Ø7.62cm
Photo of Tectonic speaker TEBM65C20F-4
Tectonic's BMR range consists of full-range speakers designed to cover a very wide part of the audible spectrum. For example, the TEBM65C20F-4 features an extended frequency response from 60Hz to 20kHz, as well as wide directivity. Furthermore, Tectonic combines flexible wave technology and a piston mode of operation to ensure high audio performance despite a very small speaker format.
Tectonic TEBM65C20F-4 speaker dimensions
Tectonic TEBM65C20F-4 loudspeaker dimensions
Product type Full-range loudspeaker
Nominal diameter 7.6cm (3-1/2")
Power Handling (RMS) 30W
Power Handling (MAX) 60W
Impedance 4 ohm
Frequency Response 60Hz-20kHz
Sensitivity 81dB 2.83V/1m
Voice Coil Diameter 2.54cm (1")
Thiele-small parameters
Resonant Frequency (Fs) 97Hz
DC Resistance (Re) 3.8Ω
Voice Coil Inductance (Le) 0.03mH
Mechanical Q (Qms) 7
Electromagnetic Q (Qes) 0.94
Total Q (Qts) 0.83
Compliance Equivalent Volume (Vas) 0.035ft³
Mechanical Compliance of Suspension (Cms) 0.47mm/N
BL Product (BL) 3.75T·m
Surface Area of Cone (Sd) 37.2cm²
Material
Cone Material Paper
Surround Material Rubber
Basket / Frame Material Polymer
Magnet Material Ferrite
Mounting information
Overall Outside Diameter 10.16 (4.25")
Baffle Cutout Diameter 7.62cm (3.25")
Depth 5.08cm (2.125")
# Mounting Holes 6
Recommanded enclosure volume
Sealed Volume 0.06ft³
Sealed F3 101.3Hz
Vented Volume 0.08ft³
Vented F3 75.1Hz
Weight 1.65kg
Package 1x Haut-parleur large bande Tectonic TEBM65C20F-4
Condition New
Avis
Comments (0)
No customer reviews for the moment.
€29.00TECTONIC TEBM65C20F-4 Full...
