FURUTECH FLOW-C15 EMI AC-1501G Main Filter IEC C15 Gold Plated Alpha Treatment Copper
Power filters
Reference 20196
Bon à savoir
The Furutech Flow-C15 mains filter protects the AC power signal of your Hi-Fi equipment. It protects your system from distortion, voltage peaks and troughs, power supply noise and high-frequency digital noise from processors and digital interconnects.Including €0.05 for ecotax
- Paiement sécurisé
Ce qu'il fait
Furutech Flow-C15 EMI AC-1501G Main Filter Gold Plated α (Alpha) Copper IEC C15
The Furutech Flow-C15 mains filter protects the AC power signal of your Hi-Fi equipment. It protects your system from distortion, voltage peaks and troughs, power supply noise and high-frequency digital noise from processors and digital interconnects. To achieve this, the Flow-C15 is based on the use of an AC-1501 (G) EMI filter connector and copper alloy conductors with α (Alpha) treatment and 24k gold plating.
As an added bonus, its slim form factor means it can also be used on TVs or low-profile devices.
In terms of performance, the Flow-C15's parallel circuit with coil and in-line capacitor reduces noise at 100 KHz by 8dB, at 500 KHz by 14dB and at 10MHz by over 30dB.
| Specifications | |
| Product type | IEC C15 mains filter |
| Connector | AC-1501 (G) with EMI filter |
| Connectors contacts | Copper α (Alpha) 24k gold-plated |
| Cable conductors | 37x Copper strands μ-OFC α (Alpha) silver plated (0.25mm x2) 37x Copper strands μ-OFC α (Alpha) (0.25mm x1) |
| Insulation | PE |
| Shielding | Copper braid α (Alpha) (Ø0.12mm) |
| Sheath | PVC |
| Noise reduction | 100kHz (8dB) 500kHz (14dB) 10MHz (30dB) |
| General | |
| Current/Voltage | AC 125V 15A AC 250V 10A 50/60Hz |
| Package | 1x Furutech Flow-C15 |
| Condition | New |
| EAN13 | 4580370444896 |
