Automatic Power Suplpy Switching Module
Power Supply Accessories
PCB ConnectorPCB Connector220.0NC220.0Trigger
Reference 17885
Bon à savoir
This power supply switching module automatically switches an amplifier on and off when the module receives an audio signal with a level above 500mV.
€20.90Tax incl.
2 years warranty
Available now
  • Paiement sécurisé
Ce qu'il fait
Module de commutation d'alimentation automatique
Module de commutation automatique d'alimentation
This power supply switching module automatically switches an amplifier on and off when the module receives an audio signal with a level above 500mV. So, when the audio input detects a corresponding signal, the module's relay closes immediately and the amplifier switches on. Conversely, if no signal is received on the audio input, the relay switches again and the amplifier switches off automatically after about 90 seconds. A two-pin connector also allows integration of an external bistable switch button (not supplied) to force the amplifier to switch on.
1 Audio signal input
2 2-pin bistable switch button connection (not included)
3 220VAC Live input
4 220VAC Neutral input
5 220VAC Neutral output
6 220VAC Live output
Trigger threshold at -36dB. Can be increased by adding a 4.7k resistor between pin 1 and pin 2 of the 2072 IC.
Product type Power supply switching module
Operating voltage 220VAc
Audio control signal level > 500mV
Dimensions 85*58*40mm
Mounting holes spacing 77.5*52mm
Weight 152g
Package 1* Power supply switching module
Lugs
Screws
Condition New
Input PCB Connector
Output PCB Connector
Output voltage (V) 220.0
Output current (A) NC
Input voltage (V) 220.0
Power Supply Trigger
Avis
Comments (2)
Grade 5/5
No customer reviews for the moment.
€20.90Automatic Power Suplpy...
