IAN CANADA UCCONDITIONER PRO 2025 400F Ultra Capacitor Conditioner Board 3.3V
Power Supply Accessories
Reference 21037
Bon à savoir
The Ian Canada UcConditioner Pro 2025 3.3V is a supercapacitor signal conditioning module operating with a 3.3V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimising stability and maximum current delivery.
€155.00Tax incl.
Including €0.05 for ecotax
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
Ian Canada UcConditioner Pro 2025 3.3V 400F 400F Ultra Capacitor Conditioner Board 3.3V
Ian Canada UcConditioner Pro 2025 : Front view
For audiophiles, upgrading their power supply with the UcConditioner Pro 2025 may prove to be one of the best solutions for achieving significantly better sound quality.
Ian Canada UcConditioner Pro 2025 3.3V: Key point
The UcConditioner Pro 2025 is based on a low-resistance MOSFET architecture, with automatic charge management, active supercapacitor balancing and LED status indicators. It uses a PCB designed for high current and very low ESR, and operates at 3.3V in plug & play mode with output instantly following input.
Ian Canada UcConditioner Pro 2025 3.3V: New features in version 2025
This version incorporates pre-assembled 400F low ESR supercapacitors, a 4-layer PCB with thickened copper, high-efficiency power management that reduces charging time and EMI noise, as well as enlarged connectors and vertical mounting brackets for easy integration.
Ian Canada UcConditioner Pro 2025 : Dimensions and Spacing holes
Product type Signal conditionner
Input voltage 3.3V
Output voltage 3.3V
Capacity of supercapacitors 400F
Dimensions 85 x 55.5mm
Mounting holes spacing 81.5 x 49mm
Package 1x Ian Canada UcConditioner Pro 2025 3.3V
Condition New
Avis
Comments (0)
No customer reviews for the moment.
€155.00IAN CANADA UCCONDITIONER PRO...
