Preamplifier 5.1 / 2.0 Module with Tone Control 7x AOP NE5532 DIP8
Preamplifier modules
PCB ConnectorScrew terminals6
Reference 12802
Bon à savoir
This really complete preamplifier module has the particularity of offering a choice of connecting a 2.0 system or a 5.1 system, via a remote module (supplied, with its connection cable). So whether you have a classic system or a home theater system, this preamplifier will blend perfectly with your hardware.
€32.90Tax incl.
Including €0.01 for ecotax
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
Preamplifier & Volume/Tone Control
7x AOP NE5532 - 5.1 / 2.0
Préamplificateur et contrôle de volume 5.1 / 2.0
A complete preamplifier module
7x AOP NE5532 and quality components
This tone controlled preamplifier is based on a series of 7 operational amplifier TI NE5532, one per channel plus another for the filter, combining excellent DC and AC characteristics. They offer very low noise and distortion ensuring a clean signal.
Also on the board are 2x1000µF Ercon Japanese capacitors for the main filter or 1A rectifier bridges to obtain a stable continuous signal. On the resistors side, these offer an accuracy of +-1% allowing to obtain a very good Signal/Noise Ratio. There are also Siemens 1µF capacitors from Germany, ensuring soft highs and deep bass.
Accurate volume/tone control
This module integrates no less than 6 potentiometers allowing you to precisely adjust each element of your system. So you can change the sound of your surround speakers, headphones, center speaker and subwoofer separately. It is also possible to adjust the low frequencies in order to obtain a more homogeneous, more coherent reproduction. Finally, once these adjustments have been made, a potentiometer is used to adjust the overall volume for greater simplicity.
There is also a small switch on the module to invert the subwoofer phase to match the phase rotation of your speakers. So your speakers and subwoofer will work in perfect harmony.
Preamplifier board diagram
schema preamplificateur
1 Power Supply AC 15V-0-15V
2 Low frequency filter
3 Subwoofer volume
4 Center speaker volume
5 Surround speaker volume
6 Front speaker volume
7 Main volume
8 Outputs
9 Inputs
10 Subwoofer phase reversal switch
Input board diagram
entrées module préamplificateur
1 MR = Front right speaker
2 ML = Front left speaker
3 Subwoofer
4 CEN = Center speaker
5 SR = Right Surround
6 SL = Left Surround
7 Left AUX
8 Right AUX
Channels 5.1 or 2.0
Available controls Main volume
Subwoofer volume
AOP 7x NE5532P (on DIP8)
Subwoofer phase switch Yes - 180°
Power supply AC 15V-0-15V
Preamplifier board dimensions 201 x 49 x 29mm
Preamplifier board fixation holes spacing 194mm /42mm
Inputs board dimensions 76 x 32 x 31mm
Weight 155g
Package 1x Preamplifier module
1x Inputs board
1x Connection ribbon cable
Condition New
Input PCB Connector
Output Screw terminals
Channel 6
Avis
Comments (0)
No customer reviews for the moment.
€32.90Preamplifier 5.1 / 2.0 Module...
