AIYIMA T20 Tube Balanced Preamplifier 2xECC83
Preamplifiers & Volume Controllers
Reference 21019
Bon à savoir
The Aiyima T20 is a simple yet elegant balanced preamplifier. It features two ECC83 tubes combined with LME49720 and OPA1612 chips to deliver the warm, smooth sound typical of tube amplification. For further convenience, the T20 includes a 12V trigger input and output, allowing for seamless integration into your audio system.
€165.00Tax incl.
Including €0.05 for ecotax
2 years warranty
  • Paiement sécurisé
Ce qu'il fait
Aiyima T20 Tube Balanced Preamplifier 2xECC83
Aiyima T20 : Front view
Aiyima T20: Twin ECC83 tube
The T20's amplification stage relies on two ECC83 tubes. These are combined with pre-amplification by LME49720 and OPA1612 chips, mounted to take full advantage of the character of the ECC83 tubes and provide them with a 180V signal. Furthermore, the T20 offers sound customisation through the use of interchangeable tubes such as 12AX7-S, 12AX7B, 7025 or 12AX7, depending on listening preferences.
Aiyima T20 : OPA
Aiyima T20 : Aluminum chassis
Aiyima T20: A sleek design
The T20's aesthetic is both sober and elegant: a large, minimalist volume display makes it easy to read the settings, while the CNC-machined aluminium casing ensures a neat finish, good heat dissipation and a visually striking appearance.
Aiyima T20 Overview
Aiyima T20 : Overview
1 Infrared receiver
2 Input mode indicator light
3 Display
4 ON / OFF / Volume control
5 Trigger input/output
6 12V DC power socket
7 Stereo XLR output
8 Stereo RCA output
9 Stereo RCA input
10 Stereo XLR input
Product type Préamplificateur
Supplied tubes 2x ECC83
Inputs 1x Single-ended stereo RCA
1x Balanced stereo XLR
Outputs 1x Single-ended stereo RCA
OPA 3x LME49720
2x OPA1612
Noise 20µV
Signal-to-noise ratio (SNR) ≥ 112dB
Dynamic range 109dB
Total harmonic distortion more noise (THD+N) 0.003%
Frequency response 20Hz-20kHz (±0.2dB)
Compatible tubes ECC83
12AX7-S
12AX7B
7025
12AX7
Power supply 12V DC
Dimensions 90 x 142 x 46mm
Weight 1015g
Color Black
Package 1x Aiyima T20
1x Remote control
2x ECC83 tubes
1x AC adapter to DC jack
Aiyima T20 : Measurements
Condition New
Avis
Comments (0)
No customer reviews for the moment.
€165.00AIYIMA T20 Tube Balanced...
