AUDIOPHONICS JC2-FET Preamplifier Volume Control Source Selection 4x RCA
Preamplifiers & Volume Controllers
Reference 14774
Bon à savoir
This neatly designed preamplifier & source selector (4 inputs) has two separate circuits for each channel of the stereo signal. Each of these circuits operates in pure Class A and is powered by its own regulated linear power supply to provide extremely clean channel separation and maintain full signal precision.Including €0.05 for ecotax
Available soon 06/07/2024
- Paiement sécurisé
Ce qu'il fait
Preamplifier - Volume control - 4x input source selector - Class A double linear power supply
This neatly designed preamplifier & source selector (4 inputs) has two separate circuits for each channel of the stereo signal. Each of these circuits operates in pure Class A and is powered by its own regulated linear power supply to provide extremely clean channel separation and maintain full signal precision. Each of the channels is driven by JFET K170BL / J74BL.
The JC2-FET has an elaborate analog circuit with separate pre-amplified channels fed separately with a combo of toroidal transformers. It offers volume control via a rotary potentiometer located on the front panel.
The device also offers a source selection function on its 4x stereo inputs (RCA connectors) mounted on its rear panel.
The source selection is made using a rotary selector located on the front panel.
The rear panel includes all input and output connectors to allow clean and tidy wiring. The analog output is available on a stereo RCA connector and will thus be able to work with most of your amplifier models.
There is also the power connector (IEC) designed for 220V voltages.
| Specifications | |||
| Type | Preamplifier Source selector |
| Inputs | 4x RCA stéréo | ||
| Outputs | 1x RCA stéréo | ||
| Frequency response | 20Hz-45kHz | ||
| Input sensitivity | 2V RMS | ||
| Output level | 9V RMS | ||
| Output impedance | 100 Ohm | ||
| Gain | 13dB | ||
| SNR | 103dB | ||
| Dimensions | 330 x 62x 308mm | ||
| Weight | 4.2kg | ||
| Power Supply | Linear regulated AC220V (Power cable NOT included) |
| Condition | New |
| Input | RCA |
| Output | RCA |
| Color | Silver |
| Class | Class A / AB |
| Remote Control | No |
