DENAFRIPS ATHENA 12TH Discrete Balanced Preamplifier Pure Class A Black
Preamplifiers & Volume Controllers
Reference 19822
Bon à savoir
Embark on an unprecedented audio journey with the Denafrips Athena 12TH discrete balanced preamplifier, the pinnacle of sonic sophistication and performance. Designed and built with uncompromising dedication, the Denafrips Athena embodies a true feat of audio innovation and craftsmanship. Built to exacting standards, this incredible model sets a new benchmark in performance, revealing incredible precision and musicality.
€2,290.00Tax incl.
Including €0.05 for ecotax
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
Denafrips Athena 12TH Discrete Balanced Preamplifier Pure Class A Black
Denafrips Athena 12th : Front view
The Denafrips Athena 12TH benefits from a fully symmetrical, pure Class A architecture of the highest quality. The entire unit uses high-end electronics, including a 60-step relay attenuator to keep crosstalk to a minimum, with precisely matched resistors ensuring perfect channel balance and extremely low distortion. The result is a rich, pure sound.
All Athena components are housed in a sturdy, modern aluminum chassis. It also features a front-panel display to show the selected volume level. All functions can be accessed remotely via the associated remote control.
Points clés :
  • Pure class A. True balanced, discrete, high-quality line stage
  • Microprocessor-controlled 60-step relay volume attenuator
  • High-precision resistors and components throughout with perfect channel balance and low distortion
  • Remote control
Denafrips Athena 12TH : Vue interne
Denafrips Athena 12TH: Tailor-made power supply
For this Athena 12TH, Denafrips has paid particular attention to its on-board power supply stage, an essential step in delivering impeccable sound quality. The power supply section, nestled beneath the main control board, incorporates two large toroidal transformers and benefits from double-layer shielding using MU metal foil to effectively attenuate EMI / EMF disturbances. This meticulous design guarantees an impeccable power supply to the audio circuits.
Denafrips Athena 12TH : Power supply stage
Denafrips Athena 12TH : Connectors
Denafrips Athena 12Th : Connectique
1 / 3 Balanced XLR inputs
2 Single-ended RCA input
4 Unbalanced RCA output
5 Balanced XLR output
6 Trigger input
7 Trigger output
8 Power connector
Product type Discrete balanced preamplifier
Architecture Pure class A
Attenuator Microprocessor-controlled 60-step relay attenuator
Inputs 4x Balanced stereo XLR
1x Single-ended stereo RCA
Outputs 1x Single-ended stereo RCA
1x Balanced stereo XLR
Input impedance Single-ended: 12.2kΩ
Balanced: 60kΩ
Output level RCA: 2Vrms
XLR: 4Vrms
Output impedance Single-ended: 200Ω
Balanced: 400Ω
Gain Unity gain, 0dB
Frequency response 10Hz - 85kHz (-0.3dB)
THD+N 0.00012%
SNR 127dB
Dynamic range > 121dB
Crosstalk -110dB
Supply voltage 100-240VAC 50/60Hz
Consumption 25W
Color Black
Dimensions 430 x 380 x 95mm
Weight 18kg
Package 1x Denafrips Athena 12TH
1x Remote control
Condition New
EAN13 6978350850283
Avis
Comments (0)
No customer reviews for the moment.
€2,290.00DENAFRIPS ATHENA 12TH Discrete...
