XDUOO MH-02 Tube Preamplifier / Headphone Amplifier / DAC CS43131 32bit 384kHz DSD256
Preamplifiers & Volume Controllers
Reference 19326
Bon à savoir
Particularly versatile, xDuoo's MH-02 is a tube preamplifier, headphone amplifier and USB DAC in one. Its preamplifier stage is equipped with a pair of 6J1 tubes for a warm, musical sound. The device's Class A buffer uses transistors to deliver high power output and greater sonic precision and dynamics.
€145.00Tax incl.
Including €0.05 for ecotax
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
xDuoo MH-02 Tube Preamplifier / Headphone Amplifier / DAC CS43131 32bit 384kHz DSD256
xDuoo MH-02: Front view
Particularly versatile, xDuoo's MH-02 is a tube preamplifierheadphone amplifier and USB DAC in one. Its preamplifier stage is equipped with a pair of 6J1 tubes for a warm, musical sound. The device's Class A buffer uses transistors to deliver high power output and greater sonic precision and dynamics. The MH-02 is thus also capable of accompanying the vast majority of headphones, thanks to an output power of 1300mW at 32Ω and three headphone outputs in 3.5mm jack, 4.4mm balanced jack and 6.35mm jack formats.
In addition to its stereo RCA input and output, the MH-02 features a USB-C digital input. This is associated with a CS43131 DAC chip capable of supporting high sampling rates, up to PCM 32bit 384kHz and DSD256, while ensuring low noise levels.
xDuoo MH-02: Description diagram
1 Jack 6.35mm headphone output
2 Jack 4.4mm balanced headphone output
3 Jack 3.5mm headphone output
4 Volume control
5 Gain selector
6 AUX RCA input
7 AUX RCA output
8 USB-C input
9 Power input
10 Power switch
Product type Tube preamplifier
Headphone amplifier
DAC
Inputs 1x USB-C
1x Stereo RCA
Outputs 1x Stereo RCA
1x Jack 3.5mm single-ended headphone output
1x Jack 4.4mm balanced headphone output
1x Jack 6.35mm single-ended headphone output
DAC chip CS43131
Tubes 2x 6J1
Supported sampling rates PCM up to 32bit 384kHz
DSD up to DSD256
Headphone output power 1300mW @ 32Ω
Frequency response 10Hz - 60kHz (±0.5dB)
Gain (switchable) +12/18dB
THD+N ≤ 0.8% (1kHz, 32Ω)
SNR 118dB
Crosstalk ≥ 70dB
Supply voltage 12VDC 2A (Jack 5.5 / 2.5mm)
Dimensions 12 x 7.8 x 4cm
Weight 350g
Housing materials Aluminum
color Gray
Package 1x xDuoo MH-02
1x 12V power adapter
1x USB-C to USB-A 1m cable
Condition New
EAN13 8413222399302
Avis
Comments (0)
No customer reviews for the moment.
€145.00XDUOO MH-02 Tube Preamplifier /...
